Home > Technical > rear window heating/defrosting |
lilweliwell Member Since: 27 Nov 2010 Location: Dublin Posts: 20 |
Hi everybody,
Mon Dec 06 2010 8:45pm |
AlexMckie Member Since: 26 Nov 2009 Location: Devon Posts: 174 |
As said.... Fuse. Relay
Tue Dec 07 2010 9:33am |
I did change the fuse...still not working...I think last time I saw it working 3 - 4 weeks ago...it wasn't so cold...since last week temp.dropped from -2 to -9. I checked the lines again - no damage...i would check the wiring under rear spoiler but don't know how |
Tue Dec 07 2010 11:27pm |
lanby Member Since: 11 Mar 2007 Location: Leeds Posts: 20 |
Hi,
Wed Dec 08 2010 1:01pm |
Yes, you can...I saw it yesterday on Ebay...have a look there |
Wed Dec 08 2010 5:05pm |
sworks Member Since: 28 Nov 2010 Location: Inverness Posts: 5 |
How do you get into the connections under the spoiler suspect I hv the same problem fuses okay
Fri Dec 17 2010 8:22pm |
gordon kerr Member Since: 14 Jan 2010 Location: Bedford Posts: 49 |
Had the same issue last winter and it was fixed by a local dealer under warranty. They said it was due to a connection which had come apart and I believe they said it was behind the trim in the drivers footwell. I got the impression that this was not an uncommon happening. Gordon Kerr
Sat Dec 18 2010 9:05am |
