Home > Technical > rear window heating/defrosting
lilweliwell
Ireland 2005 Range Rover Sport TDV6 HSE Alaska White
Hi everybody,
It was really freezing night in here. In the morning my RR was completly white. So I turned on defrosting program. Front windscreen was clean after few minutes but rear window didn't respond. Rear heating/defrosting is not working at all. I tried many times during the day.
Do you have any clue what to check? It is out of warranty, so I don't want to see my dealer if is not necessary.
Thanks
Michael
Post #282147 Mon Dec 06 2010 8:45pm
Jimmy_75000
check the fuse...??? Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #282194 Tue Dec 07 2010 7:46am
AlexMckie
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
As said.... Fuse. Relay
Did you guy check the connection under the rear spoiler....
Mine had rotted out and had to replace it.....
Alex
Post #282209 Tue Dec 07 2010 9:33am
lilweliwell
I did change the fuse...still not working...I think last time I saw it working 3 - 4 weeks ago...it wasn't so cold...since last week temp.dropped from -2 to -9. I checked the lines again - no damage...i would check the wiring under rear spoiler but don't know how
Post #282291 Tue Dec 07 2010 11:27pm
lanby
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Tangiers Orange
Connected to this, mine only works on half the screen as I think there must be a break in it, can you still purchase repair "paint" for it?
Post #282341 Wed Dec 08 2010 1:01pm
lilweliwell
Yes, you can...I saw it yesterday on Ebay...have a look there
Post #282375 Wed Dec 08 2010 5:05pm
sworks
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Galway Green
How do you get into the connections under the spoiler suspect I hv the same problem fuses okay
Where is the relay for the rear heated screen situated
Post #283261 Fri Dec 17 2010 8:22pm
gordon kerr
England 2007 Range Rover Sport TDV6 SE Java Black
Had the same issue last winter and it was fixed by a local dealer under warranty. They said it was due to a connection which had come apart and I believe they said it was behind the trim in the drivers footwell. I got the impression that this was not an uncommon happening. Gordon Kerr
Bedford, UK
2007 Java Black RR Sport TDv6
1980 Brooklands Green Triumph TR7
Post #283317 Sat Dec 18 2010 9:05am
