Home > Technical > Front Heated Screen
kelley07
Wales 2007 Range Rover Sport TDV6 HSE Java Black
Front Heated Screen
Hi - Two months ago i had a new front screen fitted by autoglass. This weekend was the 1st time i needed to use the front screen heater and it never worked but the button light did come on - Is there anything that i can check before getting back in touch with autoglass. Would the button light still come on if a fuse had blown - Thanks Mark.
Post #281416 Mon Nov 29 2010 8:29pm
madkoka
take it back to autoglass tell them of the problem and to check if the wires are connected properly, the A post trim should pull off and you can see the wires, + and - both sides.
Post #281542 Tue Nov 30 2010 7:25pm
kelley07
Thanks for the reply Madkoka - Got it booked in with autoglass on Friday - Cheers Mark
Post #281548 Tue Nov 30 2010 9:53pm
madkoka
Post #281627 Wed Dec 01 2010 1:16pm
UK Guy
England 2013 Range Rover Sport SDV6 Autobiography Santorini Black
This happened to a td5 I have 3 times!
As I don't drive it much I noticed the issue on a Sunday exactly 1 year after it was re-fitted (2nd screen). I phoned autoglass on the Monday and they stated the heated part of the screen was only guaranteed for 12 months and I was not covered as it was 1 day over!!!
They point blank refused to replace it until I really kicked up a fuss with their HQ
They eventually changed it (7months ago) and it's duff again. This time though it's streaking (not all screen is cleared)
maybe just my luck.! Big Cry
I'm not going to bother again with them. I think it's cheap parts they are using. RRS HSE with a few extras & a
2013 RRS Autobiography
Post #281664 Wed Dec 01 2010 7:56pm
