![]() | Home > Technical > Front Heated Screen |
madkoka Member Since: 25 Aug 2010 Location: High Wycombe Posts: 39 ![]() ![]() |
take it back to autoglass tell them of the problem and to check if the wires are connected properly, the A post trim should pull off and you can see the wires, + and - both sides. |
kelley07 Member Since: 22 Jun 2010 Location: wales Posts: 45 ![]() ![]() ![]() |
Thanks for the reply Madkoka - Got it booked in with autoglass on Friday - Cheers Mark |
UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149 ![]() ![]() ![]() |
This happened to a td5 I have 3 times!
