Home > General > Heated Rear Window weak elements
ray.finch
Hi All
I have a 56 plate RRS and the top three elements of the heated rear window work fine and clear the window within a couple of minutes but the rest although are working take a good 20 to 25 minutes to clear its as if the elements are weak, can anybody advise me on this??
Many Thanks
Ray
Post #281179 Fri Nov 26 2010 4:05pm
Mikie711
Scotland 2006 Range Rover Sport TDV6 HSE Rimini Red
I had the same problem with mine. That and the rear quaters wouldn't clear either. Ended up with getting the rear screen replaced which sorted the rear quarters as well. Once they start to go they can't really be repaired. No idea how much it would cost as mine was done under warrenty. Elise S1 - Race Spec
Exige S2 - Road Spec
RRS HSE TDV6 - Comfy Spec
Post #281350 Sun Nov 28 2010 9:53pm
AlexMckie
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
If you can see where the break is or where it is worn down you could try.....
http://cgi.ebay.co.uk/GRANVILLE-ELECTRO-CO...53e4915223
Post #281367 Mon Nov 29 2010 9:27am
rrspoland
Poland 2006 Range Rover Sport Supercharged Rimini Red
3 lines of mine do not work. I have this silver paint connector, but I cant locate the break or do not see where it is worn down. how else can you tell where is the damage? My name: Patryk
RRS 4.2 s/c Rimini Red
Post #281458 Tue Nov 30 2010 10:24am
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Open the tailgate and shine a bright light the other side of the glass you will clearly see the broken lines as the light will shine through. Java Black
Post #281462 Tue Nov 30 2010 10:56am
rrspoland
thanks. will try that. My name: Patryk
Post #281466 Tue Nov 30 2010 11:08am
Bradders
Ive got two bottom lines that dont work - from where I puled off the dealers bloody sticker it took off a couple of mm of element with it! FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
EX 2007 FL2 XS - not so bad
Post #281467 Tue Nov 30 2010 11:28am
1JBS
That might explain why my car arrived with the bottom elements damaged... Sad
Post #281469 Tue Nov 30 2010 11:44am
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
The wires in the rear qtr glass are not heater elements, they are the ariel wires for your in car entertainment systems. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #281533 Tue Nov 30 2010 6:44pm
