Home > General > Heated Rear Window weak elements |
Mikie711 Member Since: 21 Dec 2009 Location: Aberdeen Posts: 25 |
I had the same problem with mine. That and the rear quaters wouldn't clear either. Ended up with getting the rear screen replaced which sorted the rear quarters as well. Once they start to go they can't really be repaired. No idea how much it would cost as mine was done under warrenty. Elise S1 - Race Spec
Sun Nov 28 2010 9:53pm |
AlexMckie Member Since: 26 Nov 2009 Location: Devon Posts: 174 |
If you can see where the break is or where it is worn down you could try.....
Mon Nov 29 2010 9:27am |
rrspoland Member Since: 04 Dec 2008 Location: Warsaw Posts: 123 |
3 lines of mine do not work. I have this silver paint connector, but I cant locate the break or do not see where it is worn down. how else can you tell where is the damage? My name: Patryk
Tue Nov 30 2010 10:24am |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
Open the tailgate and shine a bright light the other side of the glass you will clearly see the broken lines as the light will shine through. |
Tue Nov 30 2010 10:56am |
thanks. will try that. My name: Patryk
Tue Nov 30 2010 11:08am |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
Ive got two bottom lines that dont work - from where I puled off the dealers bloody sticker it took off a couple of mm of element with it! FF 4.4 V8 Soooo looking forward to this bad boy
Tue Nov 30 2010 11:28am |
That might explain why my car arrived with the bottom elements damaged... |
Tue Nov 30 2010 11:44am |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 |
The wires in the rear qtr glass are not heater elements, they are the ariel wires for your in car entertainment systems. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass. __________________ Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!! |
Tue Nov 30 2010 6:44pm |
