Home > Maintenance & Modifications > Radio Removal
NeilR
Radio Removal
Hi
Well I have spent all night trying to work out how to remove the radio unit so i can plumb my ipod into the aux wires on the back of the head unit as i had done before on my disco 3, however I got the trim covers off, unscrewed the radio but it wont come out !!!!.
Has anyone been able or needed to remove the radio and if so HELP!!!!
Many Thanks Neil 2010 RRS TDV8 Overfinch GTS
Post #1218 Tue Jul 26 2005 11:09pm
1stRRS
2006 Range Rover Sport Supercharged Java Black
Isn't there the aux connector in the back near the rear lighter ? Maybe you check where those wires lead and can tap in to the source. RRS Supercharged Java Black /Ebony 1st Edition
Jakarta, Indonesia
Post #1237 Thu Jul 28 2005 8:58am
NeilR
Hi
On my D3 I did some tests that identified the wires from the aux socket in the rear to the back of the head unit which made plumbing my ipod in its cradle much smarter, it worked well on the D3 and would like to do the same on the RRS as the lose wires going between the seats and pluging in the back are anoying me already.
Post #1239 Thu Jul 28 2005 10:06am
NeilR
Hi, I have found it, I found it by looking at the install instructions for the retro fit of the Handsfree Phone Kit for the D3 and the RRS
Cheers Neil 2010 RRS TDV8 Overfinch GTS
Post #1240 Thu Jul 28 2005 10:15am
Didier_Jason
South Africa 2006 Range Rover Sport Supercharged Java Black
Radio Removal
Hi Neil,
I'm also battling with this, i've managed to remove the surrounding panel and remove the screws but it seems like the radio is catching near the bottom somewhere, could you point to the handsfree retrofit topic as I can't seem to find it.
Regards
Jason
Post #22034 Sat Apr 01 2006 1:41pm
PM member Prestige Audio they mat be able to tell you how to remove RRS TDV6 Gone but still around
Post #22036 Sat Apr 01 2006 2:15pm
ryanoz
United States 2006 Range Rover Sport Supercharged Java Black
Would someone mind telling me how you got the radio out?
I have the dash pieces off and all the screws out, but can't seem
to get the radio out.
Post #62844 Thu Oct 19 2006 7:31pm
Andy
Try a hammer. 2002 Discovery Adventurer LE
1998 Freelander xedi
Ertl limited edition RRS model number 817
Post #62848 Thu Oct 19 2006 9:22pm
pulse
Ireland 2006 Range Rover Sport TDV6 HSE Java Black
Remove the silver trim around the top and remove any screws visible. Remove the knob on the gear shilft by pulling straight up then open the arm rest box and carefully remove the the centre console ie: pocket and gear shift this will reveal more screws the aircon must come out before the radio or else you'll break clips
Post #62849 Thu Oct 19 2006 9:22pm
ryanoz
ok. that's what I figured. I was just going to take a quick peak, but I'll wait till I actually need to do the work.
Post #62850 Thu Oct 19 2006 9:25pm
rrmad
In the passenger footwell if you remove the side panel you will find a multiplug - can't remeber without looking but you will find a connection from here to aux input.
Post #62901 Fri Oct 20 2006 12:03am
fl-run
France 2006 Range Rover Sport TDV6 S Java Black
Hi,
Sorry for my pooor english... I am from France.
I am a owner of a RRS TDV6S, and i try to connect my ipod to the radio aux.
-I've tried to remove the radio panel, but it seems impossible (I removed the screws #1 ) to pull out the radio
how should I proceed ? how identify the aux wires ?
- Another way seems to find aux wires behind the foot passenger side panel (in France : driver side because LHD vehicle ?)
What are the colors of the aux wires , for connections ?
Thanks for your help
Post #69853 Sat Dec 09 2006 7:09am
rrmad
Haven't done it for a bit but you will need to get heater/vent panel out to reveal final fixings, If remember this may also mean top panel of transmission tunnel, its all quite a painful job that lot with bits that will break easy. I dont undertand why you are no picking up from the aux feed in the back, got to be easier. At my age my memory is crap so I take no responsibility for your area being littered with RRS bits - best of luck
Post #69874 Sat Dec 09 2006 12:02pm
fl-run
There is no aux wire on the rear central panel on my S version !....
Post #69876 Sat Dec 09 2006 12:19pm
fl-run
Done !!
Remove the audio unit side trim panels.
- Release the 6 clips
Remove floor consol upper panel
- unscrew the 2 screws
- release the 6 clips
Get the radio out !
2 round rubber wires
Locating the aux-in wires :
-remove the passenger side front kickpanel trim (LHD)
- disconnect the green multiplug after locating the round "rubber" wire with 3 wires (black, blue, red)
cotefarmboy said : Note: These wires terminate here and are only used if the LR DVD system is fitted so you won't cause any problem by disconnecting them.
- cut these 3 wires and connect to a standard 3.5mm stereo extension lead (black= ground, blue= right channel, red = left channel)
Plug the Ipod or any mp3 player to the 3.5 jack
Post #69879 Sat Dec 09 2006 4:01pm
