Home > Technical > How do i disable Bluetooth? |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 |
You can't disable it I am afraid....Maybe if you look at the fuse box, but it would need to be one exact fuse for the bluetooth only which I think it is not the case Range Rover Vogue ‘17 TDV6
Wed Oct 27 2010 6:45am |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 |
Pull the connectors from the module in the drivers side luggage compartment (boot). Its behind the carpet side trim panel. Surely this would stop the unit from working ?.
Wed Oct 27 2010 11:39am |
