![]() | Home > Technical > How do i disable Bluetooth? |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
You can't disable it I am afraid....Maybe if you look at the fuse box, but it would need to be one exact fuse for the bluetooth only which I think it is not the case Range Rover Vogue ‘17 TDV6
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 401 ![]() ![]() ![]() |
Pull the connectors from the module in the drivers side luggage compartment (boot). Its behind the carpet side trim panel. Surely this would stop the unit from working ?.
