Home > General > Land Rover Rear Seat Entertainment DVD |
JJF701 Member Since: 17 Dec 2007 Location: Norfolk UK Posts: 104 |
Hi
Sat Aug 14 2010 10:19am |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
Try this, contact info for Alpine UK in coventry.
Sat Aug 14 2010 4:46pm |
Thanks, i'll give them a call. |
Sat Aug 14 2010 8:20pm |
found this as well
Mon Aug 16 2010 12:14am |
Found and bought this on ebay
Mon Aug 16 2010 6:40pm |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 |
Thats the one fitted in mine |
Mon Aug 16 2010 6:47pm |
NeilR Member Since: 21 Jun 2005 Location: wakefield/West Yorkshire Posts: 246 |
Just found this for you. but it looks like your sorted.
Mon Aug 16 2010 10:18pm |
mmylonas Member Since: 16 Mar 2010 Location: Henley on Thames Posts: 15 |
I had same problem on 06 Sport SC that I bought recently which has Alpine DVD player. Took it to ICE specialist in north London who removed from car and sent it off for repair. Due to be re-fitted tomorrow. total cost about £150. The replacement Alpine was about £700 as you've been quoted. I'd be a little sceptical about a maindealer simply saying that it needs replacing unless they've had it out and looked it over.
Wed Aug 25 2010 1:33pm |
Had the new changer fitted today that was bought on ebay, it didn't work. The item was a Japan Region 2 changer NTSC and is available through Land Rover uk. Changed the screen setting from PAL to NTSC, still no luck. Can't think of any reason it shouldn't work as region 2 is region 2 no matter where it's from. Sending it back for full refund. I asked the dealer to put the old one back in for now and for some reason it's working perfectly, but for how long? Maybe all it needed was a reset and unplugging it did the trick, fingers crossed but I doubt it will stay working for long |
Wed Aug 25 2010 8:06pm |
mrobbie Member Since: 23 Jan 2011 Location: London Posts: 102 |
So an Alpine changer does not work? It has to be the land rover alpine changer? |
Sat Apr 23 2011 7:29pm |
Anyone able to clarify? |
Wed May 11 2011 9:21am |
