Home > Tips & Tricks > Towing with RRS - How To
TrackScotland
2005 Range Rover Sport TDV6 HSE Java Black
Our RRS (TDV6 HSE) developed a stutter / shudder on load (seemed to be in 3rd with in D). We got the all the transmission oils (gear box, transfer, difs) changed and so far this seems to have cured it.
We do some (once a month for say 600miles) towing of a 1300kg race car and large brian james TB trailer. So easy 2+ ton.
Can any one give some tips on how to use the gearbox when towing? I've heard its best to use it in Manual mode when setting off.
For example M1, M2, M3 then into D. Or would it just be best to stick it in Manual for all the towing?
Post #272482 Thu Jul 29 2010 9:24am
Tim in Scotland
With that much weight behind it might even be better to start in low ratio to get it moving, manually shifting L1/L2/L3 - H2/H3 then automatic high box once you are happy - you can change between low and high box when the car is in motion up to 15mph, just do it on the flat not going down a hill! It will use the low box like crawler ratios on a big truck. Manual Low first is also good for controlling the rig on a steep downhill using the engine braking 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #272484 Thu Jul 29 2010 9:38am
Gary
I regularly used to tow an industrial twin axle trailer with a RR classic on top in auto with no probs at all, only used low when manoeuvring
Post #272495 Thu Jul 29 2010 11:51am
