![]() | Home > Tips & Tricks > Towing with RRS - How To |
With that much weight behind it might even be better to start in low ratio to get it moving, manually shifting L1/L2/L3 - H2/H3 then automatic high box once you are happy - you can change between low and high box when the car is in motion up to 15mph, just do it on the flat not going down a hill! It will use the low box like crawler ratios on a big truck. Manual Low first is also good for controlling the rig on a steep downhill using the engine braking 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Gary Member Since: 22 Jun 2006 Location: Essex Posts: 268 ![]() ![]() ![]() |
I regularly used to tow an industrial twin axle trailer with a RR classic on top in auto with no probs at all, only used low when manoeuvring |
