Home > Maintenance & Modifications > Car Polishing
Harry HST
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Java Black
Car Polishing
I've purchased one of those industril buffers that looks like a sanding machine basically.
Theres no instructions in regards to using the machine.
I've got a 2 round sponges and one fury swirl add on piece, and I dont know which I would use to apply the polish to the car and what piece to buffer off with.
I can see very fine scratches on the car's body and certain area's on the bonnet which I need to buffer out.
Can anyone help?
Post #271983 Fri Jul 23 2010 8:15am
it sounds like the FURY one is a wool one, these can, in the wrong hands, cause lots of swirls etc
it also hard to say on the foam ones, as you get a multitude of foam pads also i.e ultra finishing, finishing, polishing, light cut, heavy cut etc etc
What make is the machine, and is it a rotary or a dual action one?
Any identifying brand or numbers on the foam pads?
Post #271985 Fri Jul 23 2010 8:38am
i would also look at these threads to give you a guide on how to use either a rotory or dual action polisher
http://www.detailingworld.co.uk/forum/show...ight=guide
Post #271986 Fri Jul 23 2010 8:45am
Harry HST
Cheers Pal.
I've got the rotary machine, I havn't got details of the machine or the pads to hand as i'm at work.
I've read the thread and its helped to advise how to use the rotary machine to buffer and spread but I still dont know what pad is used for what, a bit odd for the machine not to have come with instructions, it was purchased from ebay brand new!
Post #271989 Fri Jul 23 2010 9:21am
You should start off with the pad than will provide the least correction, with the least agressive polish
so something like a finish pad, then if the correction isn't coming along, up the polish to a more aggresive one, uping the pad if needs be
I would forget the wool one, for now, its not easy to tell be a finishing pad will normally be softer than say a cutting pad, so you might be able to work out the difference
to be honest it depends on what level of polishing your after, wether your looking at correcting the cars swirls or using less elbow grease
when i used my Dual Action i found a light cut and Gloss it One step Machine polish gave good results, I also got good results using a a polishing pad and Auto Glym Super resin as this fills the swirls
NickM has been on a tuition day, with a rotary so he will be better to give advice on its use, as i use a DA myself, saying that the pads used are similar
I hope i have been some help, bit hard when im not sure what you have actually got in the box etc Very Happy
Post #271992 Fri Jul 23 2010 9:34am
Harry HST
I've been using the pad with the Super Resin Autoglym product but what i've found is the polish drys up too quick when I apply it to the car and I end up using far too much polish, then i'm using the wool fury pad to buffer off the polish.
My main aim is to get rid of very light scratches on the bonnet and also the swirls on the bonnet and to be hoest with the way i've used the pads it hasn't made any different apart from making the vehichle more shiny but not getting rid of any scratches or swirls.
Post #271995 Fri Jul 23 2010 9:47am
you should use the foam pads to apply and work the polish then a microfibre cloth to wipe off, you could be inflicting more swirls in using the wool pad
With super resin polish it has just a little cutting power, but is loaded with fillers that mask the swirls, the wool pad is most likely removing these fillers
Don't get me wrong, AG SRP is a great product, but to remove swirls you need to go for other polishes with more cutting power.
There are plenty of detailers out there that can offer tuition course, showing pad and polishes combination and how to use these to provide a good quality finish
It maybe worth looking at these, for the small outlay it would cost, as i'm worried you maybe inflicting more damage than your correcting, especially using a rotary (i hope you take that in the manner i am saying it, and take no offence Thumbs Up )
Post #271999 Fri Jul 23 2010 10:02am
Harry HST
i agree, I assumed pad to apply polish and wool to buffer off obviously not the case and difficult to know unless you have guided instructions.
I will go and see a local garage that specialises in that sector to find out how much they would charge to polish and to give advise on how to polish correctly using the correct appliances.
As mentioned previously is it easy to remove the lettering on the bonnet, and would the adhesive left be easy to remove?
Post #272000 Fri Jul 23 2010 10:08am
i've never removed badges, so i could say for sure, but I presume something like a automotive glue/tar remover would remove any glue residue
Post #272001 Fri Jul 23 2010 10:20am
JC1
Harry - I have heard people say on hear about using fine fishing line or similar to get behind the lettering and cut through glue, not done it before but sounds feasable, and yes i would have thought tar remover would remove the remaining glue Thumbs Up
Let us know how you get on if you go for it Thumbs Up MY10 3.0 HSE Santorini Black, Ivory Premium & extended leather, privacy, paddles, diamond turned alloys, Ipod lead that charges, tasmods, rrsport.co.uk stickers
Jeep 4.0 High Output XJ 94 6" teraflex lift, c/w rear coils, 9500lb winch, 35" TSL super swamper boggers, safari snorkel, custom made bumpers, tom woods custom double cardon driveshaft, twin electric fans. Don't follow it..............you wont make it. The first 4 x 4 by far.
Post #272003 Fri Jul 23 2010 10:39am
Harry HST
Ok sorted.
I'm going to do give it a bash tomorrow and will put a pic up.
Cheers!
Post #272004 Fri Jul 23 2010 10:57am
JimWD
How did you get on Harry?
As above with what npinks says, you have to be very careful with the rotary machine as it can cause some nasty damage if used in the wrong hands or with the wrong product/pad combinations.
Take this 355 spider for instance:
Super Resin Polish isn't great for rotary use; the heat build-up as you found out would dry the polish out too quickly and clump everywhere. What speeds were you running the machine at? DA (dual-action) is much better suited for SRP.
I recently compelted a black Disco 3 myself and also stripped the leading badge off to machine the bonnet in its entirety. This thread may be of interest to you: http://www.cleanyourcar.co.uk/forum/viewto...ht=#100442
Keep us informed with how you get on?! Smile
Jim
Post #274256 Fri Aug 20 2010 7:51am
funnyguy1
United States 2009 Range Rover Sport 4.4 V8 HSE Santorini Black
Hi Harry,
You can remove the badges by using a hair dryer and clear fishing line. Hold the hair dryer on each letter/emblem and put the fishing line over top of each so it hangs down on each side. Slowly pull down as the dryer heats them up and they come right off. Not sure why you want to remove them but that is how they come off.
Did you purchase a buffer or orbital?? Buffer is strictly circular and orbital is..well orbital. Use only foam pads, wool takes off to much clear coat. RR puts a lot of clear coat on their finishes but you still have to be carefull.
I just did this to mine as I had a dog jump up on 3 doors scratching all but not thru clear. I used Meguiars Diamond Cut 2.0 with a foam pad. Foam will not burn thru clear unless you really push down HARD. Go over it until swirls are gone then use another clean foam pad to apply wax. Good luck!! Mike mike murphy
Post #274338 Sat Aug 21 2010 3:04am
Tim in Scotland
Dental Floss can be used if you don't have any fishing ling to hand 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #274340 Sat Aug 21 2010 7:43am
