Home > Maintenance & Modifications > Car Polishing |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
it sounds like the FURY one is a wool one, these can, in the wrong hands, cause lots of swirls etc
Fri Jul 23 2010 8:38am |
i would also look at these threads to give you a guide on how to use either a rotory or dual action polisher
Fri Jul 23 2010 8:45am |
Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296 |
Cheers Pal.
Fri Jul 23 2010 9:21am |
You should start off with the pad than will provide the least correction, with the least agressive polish
Fri Jul 23 2010 9:34am |
I've been using the pad with the Super Resin Autoglym product but what i've found is the polish drys up too quick when I apply it to the car and I end up using far too much polish, then i'm using the wool fury pad to buffer off the polish.
Fri Jul 23 2010 9:47am |
you should use the foam pads to apply and work the polish then a microfibre cloth to wipe off, you could be inflicting more swirls in using the wool pad
Fri Jul 23 2010 10:02am |
i agree, I assumed pad to apply polish and wool to buffer off obviously not the case and difficult to know unless you have guided instructions.
Fri Jul 23 2010 10:08am |
i've never removed badges, so i could say for sure, but I presume something like a automotive glue/tar remover would remove any glue residue |
Fri Jul 23 2010 10:20am |
JC1 Member Since: 24 Oct 2009 Location: Berkshire Posts: 939 |
Harry - I have heard people say on hear about using fine fishing line or similar to get behind the lettering and cut through glue, not done it before but sounds feasable, and yes i would have thought tar remover would remove the remaining glue
Fri Jul 23 2010 10:39am |
Ok sorted.
Fri Jul 23 2010 10:57am |
JimWD Member Since: 08 Jan 2010 Location: East Mids Posts: 9 |
How did you get on Harry?
Fri Aug 20 2010 7:51am |
funnyguy1 Member Since: 18 Jun 2009 Location: Sun Valley Idaho Posts: 171 |
Hi Harry,
Sat Aug 21 2010 3:04am |
Dental Floss can be used if you don't have any fishing ling to hand 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Aug 21 2010 7:43am |
