Home > Technical > Loss of power and airbag light on
afewbeers
Had an issue when I started the car this evening. It felt a bit soggy when I started it so I pressed the accelerator to rev it a little and it was hugely reluctant to rev atall, even with the accelerator pressed 3/4 down.
I turned the engine off, thinking it may be a start up software glitch. It did the same again but the airbag warning light had also come up. It would drive but was very sluggish.
Car is 06 HSE V6 with 52K, any thoughts?
Post #260219 Fri Mar 19 2010 9:33pm
