Home > Technical > Cold morning starts?
accyis
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Hi. Has anyone ever experienced your rrs running a bit rough on these cold mornings. Once the revs become steady after a few blips on the accelerator everything seems fine. It appears to miss fire at first (whilst blipping the accelerator) on the odd accassion Please help, all info welcome. Thanks
Post #256503 Fri Feb 19 2010 7:40pm
panpicker
yes the other morning car started then cut out, did this 3 or 4 times. i had to flick the key keep my foot on the pedal for 30 sec then all was fine. but no problems this morning, Very strange
Post #256507 Fri Feb 19 2010 7:50pm
NickM
Diesel or Petrol? if Diesel you must wait for the glow lamp to go out - am sure loads of people don't......
Post #256508 Fri Feb 19 2010 7:56pm
panpicker
Always wait for the glow lamp to go out. it was strange as it would not tick over.
Post #256509 Fri Feb 19 2010 8:00pm
alid32
2007 Range Rover Sport TDV6 HSE Zambezi Silver
I had the same thing late last year...
I initially though it might have been the injectors but turned out it was the EGR valves. Crying or Very sad
All sorted now though Very Happy
Post #256515 Fri Feb 19 2010 8:37pm
accyis
Hi. It is diesel and I always wait for the glow lamp to fade out before turning the key. It's going in to landrover on Tuesday and was wondering if the fault maybe covered by the warranty? Also wondered what to expect in the way of cost. Little frustrated at the mo. Thanks for helping so far. All feedback welcome. Shocked
Post #256533 Fri Feb 19 2010 10:19pm
accyis
The problem is getting worse, ie the time for the engine to run smooth is taking longer. Nearly caused an accident! Once the engine appeared to run smooth from start up i left my house. Tried to pull out of the junction at the end of the avenue and even with my foot to the floor there was nothing there at all. Censored my pants as there was a car heading down towards me. All of a sudden, it's as thoug it clears it's throat and picks up. As stated before. Once warm it's ok. Does this still sound like the EGR Valves as suggested by Alid32? All info will really help, my heart is sinking... Confused
Post #256601 Sat Feb 20 2010 4:29pm
NickM
Not sure - both my EGR valves went last week and I was still on full power
Post #256607 Sat Feb 20 2010 6:57pm
zoo
I've been trawling the forums looking for 'stumbling start' issues on my SC. This monday morning, it occurred and then drivers airbag warning light came on and stayed on. Car is still with dealer. I'm told that there is a TSB on this. Software update also. Should get it back tomorrow so will post the results for other Petrol owners.
Post #257281 Thu Feb 25 2010 9:51pm
alid32
This is the same problem that i had, the dealer put it down to the EGR's...
It cost me the best part of £900 Crying or Very sad
Let us know how you get on at the dealers.
Post #257419 Fri Feb 26 2010 8:24pm
Tim in Scotland
Zoo has a 4.2 S/C - it's a different problem on the gasoline engined cars 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #257421 Fri Feb 26 2010 8:28pm
BIG DJ
Mine is also doing this but only when the weather is cold and not too bad at the mo. Car is booked into the dealer to look at this and a couple of other issues in 2 weeks.
Post #257426 Fri Feb 26 2010 9:11pm
slcar
I had this on a TDV6 put new EGR valves and replaced two injectors that cured it but then it started again so changed the battery and it cured it so possible a voltage issue when it gets too cold!!
Post #257478 Sat Feb 27 2010 2:46pm
accyis
Hi, just a quick update on the repair work. Car been at main dealers since Tuesday and the feedback I received is that they have found the problem with the EGR valves. They tell me that this has sorted the fault........ the car still has other issues being ironed out but I'll be a bit more specific when I get the vehicle back.
Post #257489 Sat Feb 27 2010 6:47pm
zoo
still in the dealers since Monday - although I think it's because they are so busy that I doubt they have even looked at it.
Post #257500 Sat Feb 27 2010 8:11pm
