Home > General > Dipstick |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Try rotating as you pull |
Sat Jan 30 2010 4:17pm |
martsco Member Since: 22 Jan 2009 Location: Scotland Posts: 7 |
Have tried rotating it, yanking it, pulling it but with no joy. Seems to be stuck fast.
Sat Jan 30 2010 4:26pm |
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 |
As MAW says try rotating but there are a couple of O-rings sealing the yellow plastic plug/handle into the black metal tube and the plug may be rotating inside the O-rings if they are stuck to the tube. If rotating/ wiggling and pulling at the same time doesn't free it, try squirting some WD40 into the area where the plug enters the tube, more wiggling and pulling and it should come out. Tried doing it hot and cold?
Sat Jan 30 2010 4:30pm |
Thanks guys.
Sat Jan 30 2010 4:40pm |
Tried some WD and some 3-in-1 oil down the neck of the sheath but the damn things still stuck. The plastic handle turns easily and is moving up and down by about 5mm but it won't move any further. Tried taking the engine cap off just to make sure it wasn't airlocked but still no joy.
Sat Jan 30 2010 5:00pm |
Welcome to the forums Martsco, it sounds like a call at the dealership is looming! Where are you in Scotland? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Jan 30 2010 5:10pm |
Try a kettle and boiling water - pour carefully to avoid flooding any of the sensitive electronics on the worlds best offroading 4x4 and see if sudden temperature change / expansion on the neck releases it |
Sat Jan 30 2010 5:40pm |
sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961 |
What about hair dryer? |
Sat Jan 30 2010 5:47pm |
I dont think he's bothered how he looks at the minute he just wants to check the oil
Sat Jan 30 2010 5:49pm |
Sat Jan 30 2010 6:03pm |
Don't know which engine you have but part way down the dipstick (flexible cable on my TdV8) there is a crimped on guide. Just wonder whether the dipstick tube has been dented above that (about 8" from the top from memory) and this is preventing the dipstick coming out. Has any work been done in the engine bay area? Just checked mine and there is only one O ring seal. If you can get 5mm movement I can't see it being the O ring. |
Sat Jan 30 2010 6:45pm |
ASH555 Member Since: 02 Dec 2006 Location: East Yorkshire Posts: 750 |
What model year do you have?
Sat Jan 30 2010 7:11pm |
wackyjim Member Since: 12 Nov 2009 Location: Tayside Posts: 265 |
Im sure its in the engine compartment |
Sat Jan 30 2010 7:53pm |
steve2026 Member Since: 30 Dec 2009 Location: Glos UK Posts: 122 |
If you can't get the dipstick out how are you going to top up the oil
Sat Jan 30 2010 8:28pm |
