Home > Technical > satnav upgrade disc |
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 |
Have you been along any new roads yet....you know the ones with the old system that showd up as driving accross fields!
Tue Jan 26 2010 6:39pm |
rajhirani Member Since: 05 Mar 2009 Location: london Posts: 53 |
nope not yet, just put the disc in a short while ago, and from other posts thought it might change the layout and stuff on the nav.
Tue Jan 26 2010 6:42pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
The new disc should reflash the satnav's EEPROM with the latest set of instructions included on a file in the new disc, so you should have briefly seen some sort of message on the display ("Updating data files" or something like that) when you first put the new disc in the drive. You may have missed the message though - it only displays for a few seconds. Other than newly mapped streets, try checking out the list of POIs, there should be new categories added on later DVD versions compared to the original 2006. The interface tweaks have been minimal over the years - some button icons may have been replaced with text and/or slightly redesigned - so you shouldn't notice any big differences there. |
Tue Jan 26 2010 6:54pm |
cool will check later and see what it comes up with, got it off ebay, so want to check it is good, as heard a few ebayers are selling fakes and stuff.
Tue Jan 26 2010 6:57pm |
had a little play, and it seems there is something wrong can not select postcode, poi's
Tue Jan 26 2010 7:23pm |
tornado34 Member Since: 06 Dec 2009 Location: London Posts: 242 |
I have just installed 2009 / 2010 LR discs in my late 2005 and it did say it was updating. Took about 10 mins. Did you make sure the satnav was on when you ejected the old disc and inserted new one?
Tue Jan 26 2010 7:35pm |
just tried again with the nav on when i eject the disc it does say insert disc,
Tue Jan 26 2010 7:47pm |
parts numbers are:
Tue Jan 26 2010 7:50pm |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 |
Did you reselect UK? Usually when you insert a new disk the nav sistem reverts back to Belgium. '08 RRS TDV8 I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 540 |
3 DVD's??? SW
Tue Jan 26 2010 8:01pm |
Hi,
Tue Jan 26 2010 8:04pm |
again....3 DVD's? Mine was on just one and was original LR. Are you sure you haven't bought the Freelander2 set? They are a 3 disc set - I made that mistake from Ebay as many sellers don't realise Freelander are different |
not sure if it is the freelander one.
Tue Jan 26 2010 8:07pm |
Part numbers are a bit odd on the SatNav discs, depending on version and release dates I think.
Tue Jan 26 2010 8:14pm |
