Home > Technical > satnav upgrade disc
rajhirani
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Fuji White
satnav upgrade disc
bought a 2009-2010 sat nav dvd set for my my07 tdv6 hse. put the disc in and nothing happens the nav just works as normal, is it suppose to show a message lkie update done?
the previous disc was a 06 disc.
Thanks
Post #252021 Tue Jan 26 2010 6:04pm
dazsear
Have you been along any new roads yet....you know the ones with the old system that showd up as driving accross fields!
Daz 2017 4.4 Autobiography FFRR - love this car
Gone - VW T5 Transporter
Long gone - 2009 Disco
Long gone but never out of my thoughts - 2008 TDV8 HST
Post #252027 Tue Jan 26 2010 6:39pm
rajhirani
nope not yet, just put the disc in a short while ago, and from other posts thought it might change the layout and stuff on the nav.
my place is a new place and that still doesnt come up
Post #252029 Tue Jan 26 2010 6:42pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
The new disc should reflash the satnav's EEPROM with the latest set of instructions included on a file in the new disc, so you should have briefly seen some sort of message on the display ("Updating data files" or something like that) when you first put the new disc in the drive. You may have missed the message though - it only displays for a few seconds. Other than newly mapped streets, try checking out the list of POIs, there should be new categories added on later DVD versions compared to the original 2006. The interface tweaks have been minimal over the years - some button icons may have been replaced with text and/or slightly redesigned - so you shouldn't notice any big differences there.
Post #252031 Tue Jan 26 2010 6:54pm
rajhirani
cool will check later and see what it comes up with, got it off ebay, so want to check it is good, as heard a few ebayers are selling fakes and stuff.
anyone else who has updated have they seen a new poi or location on there one? which maybe i could search for on the nav?
Post #252032 Tue Jan 26 2010 6:57pm
rajhirani
had a little play, and it seems there is something wrong can not select postcode, poi's
when you press the icon it beeps as normal but nothing happens Sad
Post #252036 Tue Jan 26 2010 7:23pm
tornado34
2006 Range Rover Sport TDV6 HSE Zambezi Silver
I have just installed 2009 / 2010 LR discs in my late 2005 and it did say it was updating. Took about 10 mins. Did you make sure the satnav was on when you ejected the old disc and inserted new one?
They was a few layout changes, but that's because I came from such an old version. I have heard that after 2007 ish, the layout changes and differences are very subtle.
Set the country to Sweden and look up a street name called ryssjan, it wasn't in my previous version, but it is in the new one. Make sure you change the country at the begining though or you won't see it. Then you will know it's 2009 / 2010.
Thumbs Up [/b]
Post #252041 Tue Jan 26 2010 7:35pm
rajhirani
just tried again with the nav on when i eject the disc it does say insert disc,
then out the disc in and nothing happens Sad
have i been had Sad
Post #252046 Tue Jan 26 2010 7:47pm
rajhirani
parts numbers are:
LAND ROVER PART NO 6G92-10E898-EE
DENSO PART NO 104632-9470
3 dvd's
Post #252048 Tue Jan 26 2010 7:50pm
flydive
Did you reselect UK?
Usually when you insert a new disk the nav sistem reverts back to Belgium. '08 RRS TDV8
Post #252049 Tue Jan 26 2010 7:50pm
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
3 DVD's??? SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #252054 Tue Jan 26 2010 8:01pm
rajhirani
will check to see if i have selected uk in a bit, yes 3 dvd's as it covers europe aswell, is this not correct?
Post #252057 Tue Jan 26 2010 8:04pm
tornado34
again....3 DVD's? Mine was on just one and was original LR. Are you sure you haven't bought the Freelander2 set? They are a 3 disc set - I made that mistake from Ebay as many sellers don't realise Freelander are different Crying or Very sad
Post #252058 Tue Jan 26 2010 8:04pm
rajhirani
not sure if it is the freelander one.
can someone confirm with the part numbers?
parts numbers are:
Post #252059 Tue Jan 26 2010 8:07pm
tornado34
Part numbers are a bit odd on the SatNav discs, depending on version and release dates I think.
My Freelander2 discs were 2008 / 2009 so the numbers wouldn't match yours anyway. The answer lays in the fact that you have a 3 discs set I think. I re-sold mine on ebay for an OK price, but did lose out Big Cry
I can point you towards the Ebay seller I bought mine from if it helps, he was really useful.
Post #252063 Tue Jan 26 2010 8:14pm
