Home > For Sale & Wanted > Rear Numberplate Bulb Holder
merwiz
Ladies and Gents,
I am in need of the above part for my car, can't seem to find online or on eBay.
Need 1 or a pair, as I broke the retaining tabs fitting LED bulbs (not worth the money, as very dim!)
Any ideas?
Thumbs Up I keep telling myself 'It's a toy'
But I've broken quite a lot of toys in my time.....
Post #248590 Fri Jan 08 2010 6:58pm
tornado34
2006 Range Rover Sport TDV6 HSE Zambezi Silver
Aha, this probably explains why one of mine is taped up?!?!
However, I have ordered a set of LED's for the numberplate but have not yet received them - I am now a little concerned that they are cr4p from your comments.
Are they really so bad? Are you going to swap back to filament bulbs?
What spec are your LEDS - how many LEDS do they have in each lamp? I think they come in different amount so as to vary the output. Let me know and we could compare. I know this was the case when I changed some front DRL on my Audi, a huge diffence in spec between the manufacturers of the same fitting lamp.
Post #248611 Fri Jan 08 2010 8:04pm
NickM
No some good LED bulbs out there - mine are very bright - will change my interior ones next week..if anyone would care to tell me how to o them - it would be appreciated.
Post #248621 Fri Jan 08 2010 9:28pm
merwiz
Mine came from eBay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...AQ:GB:1123
I'm trying to get a refund/swop.
They're single LED I think
Big Cry I keep telling myself 'It's a toy'
Post #248711 Sat Jan 09 2010 3:12pm
Tim in Scotland
There used to be a very long thread about fitting LED's inside and to the number plate over on Freel2. I'm sure NPinks will be able to tell us more! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #248715 Sat Jan 09 2010 3:42pm
http://www.freel2.com/forum/topic3172.html
Post #248727 Sat Jan 09 2010 4:45pm
Ambrez
Had these LED number plate bulbs off ebay, waste of time, they look good but last a week then start to flicker then stop working, contacted seller, same happened again,
so replaced with standard ones
also broke one of my number plate bulb holders, cost me £15 from dealer
Ambrez
Post #248729 Sat Jan 09 2010 4:58pm
NickM
Yes they do flicker after a while but mine last about 6 months and then a quick change......thats for the link npinks Thumbs Up
Post #248747 Sat Jan 09 2010 6:30pm
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Found this full conversion kit for the RRS on fleabay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...K:MEWAX:IT
I only ordered these LED's for my RRS side lights. Choose those because they are the only LED's which also look good when not lighted:
http://cgi.ebay.co.uk/Xenon-W-501-LED-Side...4398ec61d5 SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #248754 Sat Jan 09 2010 6:51pm
rajhirani
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Fuji White
Hi,
got some led's for mine got the new smd led bulbs these are much better.
got the 6 smd led bulbs for the sidelights and it looks very good.
Got the 4 smd led bulbs for the number plates and there are very bright and look good.
Regards,
will get some pics tomorrow
Post #248953 Sun Jan 10 2010 11:29pm
merwiz
Cheers rajhirani,
I'd like to see them, and a link to where you bought them from if possible?? I keep telling myself 'It's a toy'
Post #248977 Mon Jan 11 2010 9:22am
rajhirani
Hi,
here's the links:
front sidelights
http://cgi.ebay.co.uk/SMD-LED-XENON-SIDELI...4cea386fa3
rear number plate lights:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...764wt_1161
hope this helps.
Post #249007 Mon Jan 11 2010 10:58am
rajhirani
here are the pics of them on my car, took the pics with the flash off:
in the pics they look a bit blue, but they are white.
Post #249018 Mon Jan 11 2010 11:17am
tornado34
This is the Ebay place I got mine from. I have just fitted the number plate lights and they look great - I absolutely would recommend you do it.
Be careful when you remove the light fittings, sounds like many people have broken the fitting trying this mod. It comes out from the opposite end than you think (ie, NOT the end with a little access slot). Gentle prise the other end with a couple of broad blade flat screwdrivers, to spread the load, and it just comes out.
There is a great thread on how to change the front sidelights too on here.
Post #249106 Mon Jan 11 2010 4:58pm
