Home > General > Hill descent control |
kcsun Member Since: 25 Dec 2008 Location: essex Posts: 13 |
Thought I had better give you all a second dose of my avatar, (bet you can't guess my current car brand )
Thu Dec 24 2009 11:22am |
KC, all you need touch is the steering, HDC will look after the braking and speed, you will not stop but you will go very slowly. If you feel it safe to go a little faster then the HDC speed can be adjusted up or down using the +/- button of the the cruise control. If the hill is a steep down slope I would also put the TR into Grass/Gravel/Snow and switch from hi to lo box as Low 1st will provide plenty of engine braking which will help the HDC. DO NOT PRESS THE BRAKE PEDAL, that will over-ride the HDC which will progressively fade out. Once the downslope has been negotiated then disable the HDC and switch back to Hi box. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Dec 24 2009 1:39pm |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
Tim, forgot to tell you the most important bit.........you need to be in Neutral to change from High range to Low range and vice versa TDV6 - gone TDV8 - gone Audi Q5 3.0 Tdi Sline wef 6/11/10 |
Mon Dec 28 2009 9:53am |
gianluca Member Since: 18 Mar 2009 Location: Potenza Posts: 136 |
Sorry guys for bothering you, but I have two quick questions about my 2006 RRS TDV6 HSE:
Sun Jan 03 2010 11:33pm |
1) YES
Sun Jan 03 2010 11:43pm |
Thanks mate!
My gallery: http://www.rrsport.co.uk/gallery/thumbnails.php?album=994 |
Mon Jan 04 2010 1:04pm |
