![]() | Home > Maintenance & Modifications > Warranty about to expire should i get a check up? |
Yep, very much so. Get anything sorted on warranty now while you still can |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 ![]() ![]() ![]() |
As you have only just purchased the vehicle, then most definitely the answer is - yes. Take it to an independent LR specialist and get them to check it over properly for you. If done properly it will cost you a few quid but this will either give you future peace of mind or be a very good investment if things need attention and are covered under the factory warranty. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
islider Member Since: 19 Jun 2009 Location: Deepest Darkest Hedgeland Posts: 457 ![]() ![]() ![]() |
Also your MOT should be due, if the Dealer you bought from didn't already test it.
barnetda Member Since: 22 Oct 2009 Location: Herts Posts: 12 ![]() ![]() |
Thanks guys.
There is an Indy in Woodford Green near Charlie Browns Roundabout on the A406, called Les Pauls.
Just called LesPAuls and they seem very professional. `Will be taking into them.
Let me know how you get on with them, as they're not far from me and might consider using them in the future.
will do. |
XUJG Member Since: 03 Aug 2006 Location: Left Posts: 437 ![]() |
Hi Inslider, what did you mean by you have 30 days before your cars 3rd birthday? My car is three on the 21st Dec does that mean I need to get it checked before the 21st November? |
V8 andy Member Since: 11 May 2009 Location: east yorkshire Posts: 540 ![]() ![]() ![]() |
i think what he means john is you can take your car for mot a month before it expires then they will give you a 13 month ticket. but im sure i read somewhere that you can no longer do that. ![]() 1980 Rolls Royce,shadow 2 in white. Gone 07/57 TDV8 santorino,black leather.chrome handle's/mirror's. Gone 02/52 FFRR vogue. |
Jon, Andy,
