Home > General > PS3 SLIM LINE ... HELP ..
JEDS_RANGE
England 2006 Range Rover Sport Supercharged Santorini Black
Hi ..
i have a RR sport that has Land Rover dvd with 2 screens at rear,and front .. My question is using the Aux can i put my ps3 SLIM LINE and make it play on the back screens .... is it easy to do can any one help me ? THANKS Wink J.D
Post #240042 Wed Oct 14 2009 12:27pm
dazsear
Knowing Land Rover I doubt it will be a simple plug and play affair!
I have aftermarket screens in mine so the PS3 works well, my lad loves it!
Daz 2017 4.4 Autobiography FFRR - love this car
Gone - VW T5 Transporter
Long gone - 2009 Disco
Long gone but never out of my thoughts - 2008 TDV8 HST
Post #240046 Wed Oct 14 2009 1:04pm
jambo
Not sure what outputs what there is on the PS3 but you should be able to plug the PS3 into the sockets that are under the plastic flap behind the centre console. On mine there is an audio left and right along wth a video input. Providing you can get a lead from the PS3 that terminates into 3 phono's there should be no reason why it won't work. On the rear screen entertainment option on the the touch screen you just select aux1 or aux2 depending on which input you have used and it should work. You will need to run an invertor to power the PS3 and becareful not to use it too much when the engine is running as it can drain the battery quite quickly. 2005 TDV6 HSE Zermatt Silver Ebony Interior Sunroof, RSE, Side Steps
2002 Honda CBR600F4i plenty fast enough thank you !
Post #240054 Wed Oct 14 2009 2:55pm
