![]() | Home > General > PS3 SLIM LINE ... HELP .. |
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 ![]() ![]() |
Knowing Land Rover I doubt it will be a simple plug and play affair!
jambo Member Since: 31 Aug 2008 Location: Stoke on Trent Posts: 59 ![]() ![]() ![]() |
Not sure what outputs what there is on the PS3 but you should be able to plug the PS3 into the sockets that are under the plastic flap behind the centre console. On mine there is an audio left and right along wth a video input. Providing you can get a lead from the PS3 that terminates into 3 phono's there should be no reason why it won't work. On the rear screen entertainment option on the the touch screen you just select aux1 or aux2 depending on which input you have used and it should work. You will need to run an invertor to power the PS3 and becareful not to use it too much when the engine is running as it can drain the battery quite quickly. 2005 TDV6 HSE Zermatt Silver Ebony Interior Sunroof, RSE, Side Steps
