Home > Technical > Rough when starting but only for the first 10 seconds or so? |
slcar Member Since: 24 Sep 2009 Location: Wigan Posts: 23 |
From cold start the engine has a really rough vibration but only for about the first ten seconds then it is fine. Can anyone help with this please? |
Thu Sep 24 2009 12:43pm |
It is the TDV6 so if its common im not concerned just didnt want it to develop into something serious. I have just added a fuel treatment to the tank so see if it eases up any over the next few days! |
Thu Sep 24 2009 1:09pm |
islider Member Since: 19 Jun 2009 Location: Deepest Darkest Hedgeland Posts: 457 |
Keep an eye on it, but if it is as short lived as you describe, it's nohing to worry about.
Thu Sep 24 2009 1:15pm |
Thank you for your response.
Thu Sep 24 2009 1:28pm |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 |
Some use 2 stroke oil in their fuel tank, if you do a search you'll find it discussed at length. |
Thu Sep 24 2009 10:42pm |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 |
I have same noise on mine and it was the same on the one before so normal me thinks!! |
Mon Sep 28 2009 2:38pm |
Tried the fuel additive and it hasnt made any difference so Im gonna give the 2 stroke oil a go and see if that helps. Does anybody know exactly which oil is recommended please? |
Thu Oct 01 2009 10:28am |
Forum supporter, Opie Oils should be able to help out with this one
Thu Oct 01 2009 10:44am |
Thanks Shmoogle.. |
Thu Oct 01 2009 10:54am |
There are some threads on this site, but I believe it all originated on this thread over on freel2:
Thu Oct 01 2009 11:09am |
