Home > Technical > Newbie Q & Gearbox |
There is a known lag in the diesels (both 6 and 8-cylinder), but can be removed by chipping... speak to our forum sponsor Pete Bell at BAS - he can sort you out with something suitable.
Wed Sep 16 2009 7:08am |
Gazzer Member Since: 21 Oct 2005 Location: Salisbury Plain Posts: 318 |
Yup, that's the 'old' TD engine for you. If you know anything about turbo engines, they use the exhaust gasses to spin a compressor to charge the air into the cylinders before combustion. Trouble is the turbo is a relatively heavy thing which takes a bit of time to spin up. The new 3.0 TDV6, uses 2 turbos now to avoid this, a smaller lighter one is used to get up and go and then the larger one is used essentially from then.
Wed Sep 16 2009 7:34am |
