Home > Technical > Engine system Fault
mj345c
England 2006 Range Rover Sport 4.4 V8 HSE Bonatti Grey
Engine system Fault
yesterday morning i had a flat battery due to an interior light being left on, anyway after i jumpstarted the car, the Airbag warning light was on and temp display changed from Celsius to Fahrenheit, also the engine system fault showed briefly on the message display, when i stopped and refuelled the evrything has gone back to normal apart from the engine system fault on the message display when you scroll through the settings
any ideas or is this a mega expense at the dealer job? cheers dont let the Sh*t grind you down
Post #232576 Tue Aug 04 2009 9:31am
Jimmy_75000
France 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
how did you run out of battery with an interior lamp on??? On mine, if I lock the car with one of the rear seats reading light on, after a while, they will switch off on their one...only to go back on as soon as the car is unlock again. Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #232594 Tue Aug 04 2009 11:26am
If the battery is flat, you will get a couple of errors on startup - nothing to worry about, as you have seen they are only transient. What is more odd, like Jimmy says is that you ended up with a flat battery because of a reading lamp staying on. Confused
Post #232596 Tue Aug 04 2009 11:35am
