Home > Technical > Engine system Fault |
mj345c Member Since: 17 Jun 2009 Location: staffs Posts: 7 |
yesterday morning i had a flat battery due to an interior light being left on, anyway after i jumpstarted the car, the Airbag warning light was on and temp display changed from Celsius to Fahrenheit, also the engine system fault showed briefly on the message display, when i stopped and refuelled the evrything has gone back to normal apart from the engine system fault on the message display when you scroll through the settings
Tue Aug 04 2009 9:31am |
If the battery is flat, you will get a couple of errors on startup - nothing to worry about, as you have seen they are only transient. What is more odd, like Jimmy says is that you ended up with a flat battery because of a reading lamp staying on.
Tue Aug 04 2009 11:35am |
