Home > Technical > Wheel Alignment outside of LR specifications |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 |
Thanks - I knew how to do that! and this is what led me to assume it was car related and not camber/surface of the road. FYI - Steering rack was replaced today and alas the rattle/reverboration remains as before. The dealer has been great in the diligent effort to try and investigate and resolve it, but ( and in their words) having replaced pretty much everything around the suspected area including the steering column and rack they are now going to ask Land Rover Australia to look at the car. They also did a 4 wheel alignment today and guess what the car still seems to have a strong pull to the left! Last edited by 2nd Rower on Wed Jul 29 2009 11:57am. Edited 2 times in total |
Wed Jul 29 2009 11:46am |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 |
hate to say it 2nd, but i had more faith in a certain tyre outlet in Bentleigh than LR when it came to setting up the LR.. they had the D3 settings but could not put it in stress mode, but no bad wear at all. LR dealership had all the systems and totally screwed it up.. my faith in them is sorely tested when it comes to alignment.. Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Wed Jul 29 2009 11:51am |
redrover Member Since: 22 Jun 2007 Location: Sydney Posts: 94 |
Hi 2nd Rower, Are your tyres relatively new or quite worn? My tyres are wearing out perfectly (so the alignment is good) and at 50000km's are starting to pull a bit on heavily worn roads, which is just about every road in Sydney. I would be interested to see how you get on with the vibration. If it is the one that occurs at 1800-2000 rpm with a little bit of angle on the steering wheel then it is the same as mine. I have been fobbed off with software updates, moving around of wiring and some excuse about the torque converter locking up for too long now. I am not going to take it back till they fix it next time. Common consensus seems to be transfer box. cheers, Anthony TDV6, MYO7 Java with Ivory leather, 19 inch wheels |
Sun Aug 09 2009 6:19am |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 |
I have mentioned this before, but it's worth repeating.
Sun Aug 09 2009 10:59am |
Hi Red Rover,
Sun Aug 09 2009 11:01am |
If its is constantly pulling to the left regardless of roads, wheels, tyres and alignments, then you would be beginning to suspect power steering hydraulics or possibly even DSC (slightly braking the front left wheel)?? Is there any more brake dust on this wheel compared to the others? TDV6, MYO7 Java with Ivory leather, 19 inch wheels |
Sun Aug 09 2009 1:11pm |
Just learned of a good point from JKP regarding taking off wheels, changing for a new set, not liking them so return to set 1 and the car pulls to one side or the other............ when an hour before the steering had been fine.
Mon Aug 10 2009 5:41pm |
Thanks Tim - I'm taking a punt by assuming the dealer has followed this
Now scheduled for Friday as LRA couldn't do Wed! |
Mon Aug 10 2009 9:35pm |
I still suggest you try this. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
Tue Aug 11 2009 7:30am |
Thanks RRSJO - appreciate the input.... At this stage and 6 or so months after having asked them to align the wheels I would have hoped that such a simple resolution would have been tried by the boffins at my dealer and the Bridgestone tyre centre!
Tue Aug 11 2009 7:48am |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 |
2nd
Thu Aug 13 2009 1:13am |
So the LRA Rep had a drive with me, he asked for the the car to be realigned/tracked and tyres rotated again after I left the dealer. My perception from collecting the car is it is still pulling over and above what would be causded by any camber..
Sun Aug 16 2009 2:37am |
