Home > Technical > Brake light bulb blown
extremecapture
United Kingdom 2009 Range Rover Sport TDV8 HSE Stornoway Grey
As my brake light bulb has blown, i nee dto replace-simple job i thought, but ive taken the two screws out that hold the rear light cluster, and i assume it should just come out. But its really tight, and im worried about breaking something.......so my question is, do you just remove the two screws and it pulls out, or am i missing something?
Thanks in advance
Paul Very Happy .....................................................................
09 RRS TDV8 HSE 20"STORMERS and Colour Coded everything!!!!
Life is for living, not sitting back and waiting for rainey days!
Post #224990 Mon May 11 2009 9:07am
MAW
Does just pull out, there are two pegs in rubber grommets that 'hold well' on the opposite side to the screws. Place a dry hand on the side and hit it rearwards with your other.
Post #224996 Mon May 11 2009 9:57am
extremecapture
Yep thats worked a treat, thanks for the reply, i was just a bit unsure and didnt want to go breaking anything-many thanks Very Happy .....................................................................
Post #224997 Mon May 11 2009 10:10am
