![]() | Home > Technical > Enhanced navigation |
Springer Member Since: 10 Apr 2009 Location: Peterborough Posts: 20 ![]() ![]() ![]() |
I have just picked up my 08MY HSE but it doesn't have the off road navigation option on the screen. Can I install the enhanced nav package as an extra or am I never to see the compass! |
It should have - press the nav button under the screen then select the offroad optiion 2005 Zambezi TDV6 - Gone but not forgotten
But that's the problem, when you push the nav button there is no off road navigation option. The manual says that the off road option is only available with the enhanced navigation package. What is this and how do you get it? |
Another SW Member Since: 14 Mar 2009 Location: N Bucks Posts: 180 ![]() ![]() |
There is something wrong here... Either pilot error or manufacturer error, as Range Rover Sport in the UK only ever has 'Enhanced Navigation'.
Have now found it. Press the nav button again when on the nav screen and the off road option comes up. Happy now. Thanks. |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 ![]() ![]() ![]() |
Springer - an easy mistake to make, I only "discovered" the off road nav screen by chance after thinking I didn't have it! |
extremecapture Member Since: 14 Apr 2009 Location: Staffs/Warks Border Posts: 24 ![]() ![]() ![]() |
I sort of have the sameish problem, i get the 4x4 nav screen, but it says that the compass is not available-strange ey |
chris_J_G Member Since: 12 Apr 2007 Location: Bristol Posts: 23 ![]() ![]() ![]() |
compass will only appear when you have selected off road setting - bit silly really but there you are... MY07 TDV8 HSE (BAS Remap), Java, Privacy Glass,Tasmods. |
Thanks Chris, i suppose it would help if i read the manual ![]() |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
So you have to select mud gravel ect setting before compass is showing as mine does same and states compass not available but i am in normal highway mode ![]() |
You need 'Off-Road Navigation' setting on the touchscreen... Nothing to do with the Terrain Response setting. |
OK this is what i have, i can find no selection in navigation for off road navigation so i go into 4x4, in this section i have no selection for off road navigation and select the only button relating to compass, when pressed it is saying compass option unavailable. ![]() ![]() ![]() |
Duh |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
I've got the compass in on road mode. It appears in the top left hand corner of the screen. Has always been there. TDV6 - gone
