Home > Technical > Enhanced navigation
Springer
United Kingdom 2013 Range Rover Sport SDV6 HSE Rimini Red
Enhanced navigation
I have just picked up my 08MY HSE but it doesn't have the off road navigation option on the screen. Can I install the enhanced nav package as an extra or am I never to see the compass!
Post #223490 Sun Apr 26 2009 6:25pm
C10KO
What do you mean it does not have off-road navigation on the screen?
If the compas is the only thing you are after, it is a quick software update Thumbs Up
Post #223492 Sun Apr 26 2009 6:42pm
It should have - press the nav button under the screen then select the offroad optiion 2005 Zambezi TDV6 - Gone but not forgotten
Post #223495 Sun Apr 26 2009 7:51pm
Springer
But that's the problem, when you push the nav button there is no off road navigation option. The manual says that the off road option is only available with the enhanced navigation package. What is this and how do you get it?
Post #223525 Mon Apr 27 2009 10:30am
Another SW
There is something wrong here... Either pilot error or manufacturer error, as Range Rover Sport in the UK only ever has 'Enhanced Navigation'.
If you press the 'Hard Key' under the screen on the left hand side what do you see on the screen? If you see a map, press it again and you should see a black screen with two 'buttons': [On-Road Navigation] and [Off-Road Navigation].
Another check is the Voice Activation button on the left hand side of the steering wheel - this only comes with Enhanced navigation.
If you don't have enhanced navigation there is something wrong - is it not a UK spec car perhaps? Or is it possible that someone has put a Disco 3 Standard Nav system in by mistake during a warranty replacement or something?
Post #223528 Mon Apr 27 2009 11:03am
Springer
Have now found it. Press the nav button again when on the nav screen and the off road option comes up. Happy now. Thanks.
Post #223533 Mon Apr 27 2009 11:52am
Supacat
Springer - an easy mistake to make, I only "discovered" the off road nav screen by chance after thinking I didn't have it!
Post #223577 Mon Apr 27 2009 8:16pm
extremecapture
United Kingdom 2009 Range Rover Sport TDV8 HSE Stornoway Grey
I sort of have the sameish problem, i get the 4x4 nav screen, but it says that the compass is not available-strange ey Crying or Very sad
Post #223693 Tue Apr 28 2009 4:53pm
chris_J_G
compass will only appear when you have selected off road setting - bit silly really but there you are... MY07 TDV8 HSE (BAS Remap), Java, Privacy Glass,Tasmods.
Post #223703 Tue Apr 28 2009 5:14pm
extremecapture
Thanks Chris, i suppose it would help if i read the manual Confused
Post #223705 Tue Apr 28 2009 5:22pm
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
So you have to select mud gravel ect setting before compass is showing as mine does same and states compass not available but i am in normal highway mode Question
Post #224149 Sun May 03 2009 6:08pm
Another SW
You need 'Off-Road Navigation' setting on the touchscreen... Nothing to do with the Terrain Response setting.
Post #224150 Sun May 03 2009 6:16pm
leedsunited
OK this is what i have, i can find no selection in navigation for off road navigation so i go into 4x4, in this section i have no selection for off road navigation and select the only button relating to compass, when pressed it is saying compass option unavailable. Sad am i missing something Question
Post #224177 Mon May 04 2009 10:36am
leedsunited
Duh Thud ignore above post now found it, the left hard button next to menu button whilst in nav screen Thumbs Up
Post #224178 Mon May 04 2009 10:40am
Josh
I've got the compass in on road mode. It appears in the top left hand corner of the screen. Has always been there. TDV6 - gone
TDV8 - gone
Post #224210 Mon May 04 2009 4:37pm
