![]() | Home > Tips & Tricks > Blue dye on beige leather......... |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 ![]() ![]() ![]() |
Hi all!
This post has a few ways
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 ![]() ![]() ![]() |
http://www.furnitureclinic.co.uk/
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 ![]() ![]() |
Had the same issue, got replaced on warranty |
Johnson's baby wipes work well for this or if the colouring is a bit more stubborn, try the Meguiars Aloe Gold leather cleaner |
ayates Member Since: 08 Jun 2007 Location: Houston Texas Posts: 369 ![]() ![]() ![]() |
for VEY SMALL marks use a qtip dipped in perfume, this will remove any stain but just be careful on the size and area you treat, try out in a non obvious spot first Brit across the Pond |
Although make sure the wife knows you are doing it - could cause a lot of unnecessary questions otherwise |
Willy Wonka, how on earth did you get them to replace your seat cover under warranty? Where did you go to get it done. They are only 18 months old and are looking a bit rough as a result of this.
mccalia1 Member Since: 09 Aug 2009 Location: UK Posts: 368 ![]() ![]() ![]() |
Try the gliptone cleaner and conditioner.
no_one_has_this_name Member Since: 22 Aug 2009 Location: newcastle upon tyne Posts: 55 ![]() ![]() ![]() |
pmsl I have had that on seatbelt befoe just blamed my sister! ![]() worked a treat i got off with it ![]() |
goldleaf Member Since: 29 Mar 2010 Location: London Posts: 20 ![]() ![]() |
how on earth did you get them to replace your seat cover under warranty? Where did you go to get it done? |
DPN Member Since: 10 Jun 2010 Location: Harrogate, North Yorkshire Posts: 2 ![]() |
This is referred to as Dye transfer Here is some more info http://www.lttsolutions.net/dyetransfer.asp Here is a post on Detailing world, which i did http://www.detailingworld.co.uk/forum/show...ht=leather Regards Dave Naxton |
I bought some leather wipes from Halfords in a resealable pack
