Home > Tips & Tricks > Blue dye on beige leather.........
hoppy_70
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Rimini Red
Hi all!
I'm looking for a tip to remove blue dye from my Alpaca leather. The dye has come from blue jeans and has stained the hip of the seat as you get in. Does anyone have any ideas about how to remove it (preferably without using something that would melt through the chassis!)
In return i'll impart a couple of my own "top tips"
1) Seat belt snap! Figured this out a couple of years ago when my seat belt got trapped causing some damage to the door panel as the door slammed on it. It happened cos the seat belt had become slow to retract and I found after some experimenting that you could return them to their new "snap back" state with a quick procedure.
1st clean the area where the seat belt reels in using upholstry cleaner. grease from the seatbelt (euch!) builds up on the runner and needs to be cleaned off. Then, when dry, spray the whole area with bog standard cheap silicone spray (the kind for shining your dash). Then pull the seat belt all the way out and spray the length of it's inside as it goes back in. Thats it, the seatbelt will now snap back as though the car was brand new (this only works if your car isn't brand new!).
2) A quick 1. Badge removal..... A quick and easy way to remove the badge from the back of your car (for rebadging..... or so you can steal someones vw badge in an 80's beastie boys style!) is to use dental floss. Just run the floss down the back of the badge effectively "sawing" through the foam backing. Pick off the remainder with your fingernail or plastic tool. The residue will come off easily with car polish or tcut (careful)
(again this second tip won't work if the badge is screwed or riveted on Wink
Dont forget, if anyone has the blue dye removal tip then youre better than my upholsterer guy cos he didn't have a clue!
Post #222772 Fri Apr 17 2009 10:17pm
This post has a few ways
http://www.rrsport.co.uk/forum/topic9428.html?highlight=ballpoint 2005 Zambezi TDV6 - Gone but not forgotten
Post #222787 Sat Apr 18 2009 7:04am
Lookers Park Royal
Just don't get any chemicals on the seat belt as it could rot and therefore not serve you well if ever you need it!
Post #222795 Sat Apr 18 2009 10:05am
ChrisP
http://www.furnitureclinic.co.uk/
These guys are forum specialists on Detailing World so should be able to help. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #222797 Sat Apr 18 2009 10:52am
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Had the same issue, got replaced on warranty Thumbs Up L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #222848 Sat Apr 18 2009 9:22pm
Johnson's baby wipes work well for this or if the colouring is a bit more stubborn, try the Meguiars Aloe Gold leather cleaner Very Happy
Post #222929 Mon Apr 20 2009 8:04am
ayates
United States 2007 Range Rover Sport Supercharged Buckingham Blue
for VEY SMALL marks use a qtip dipped in perfume, this will remove any stain but just be careful on the size and area you treat, try out in a non obvious spot first Brit across the Pond Wink
07 TATA (LR) RRS SuperVindaloocharged, Buckingham Blue, Stormers, TPMS, Sunroof, Rear Difflock,PDC front & rear, Privacy, Rear twin DVD, premium ice, mudflaps, premium Ivory leather, lined oak, PTI, Sat Radio.
Post #222989 Mon Apr 20 2009 4:41pm
Although make sure the wife knows you are doing it - could cause a lot of unnecessary questions otherwise Wink
Post #223118 Wed Apr 22 2009 7:53am
hoppy_70
Willy Wonka, how on earth did you get them to replace your seat cover under warranty? Where did you go to get it done. They are only 18 months old and are looking a bit rough as a result of this.
Hoppy
Post #223390 Fri Apr 24 2009 6:02pm
mccalia1
Try the gliptone cleaner and conditioner.
http://www.liquidleather.com/car-shop.html
I've used this with a microfibre applicator pad with great success. Gone: RRS : HSE : TDv6 : 57 : Java Black : Ebony : 20"
Post #235786 Sun Sep 06 2009 8:59am
no_one_has_this_name
pmsl I have had that on seatbelt befoe just blamed my sister! Twisted Evil
worked a treat i got off with it Wink "ha ha HA HA" laughing all the way to the bank!
Post #235840 Sun Sep 06 2009 6:12pm
goldleaf
how on earth did you get them to replace your seat cover under warranty? Where did you go to get it done?
Post #274470 Mon Aug 23 2010 11:57am
DPN
Re: Blue dye on beige leather.........
hoppy_70 wrote:
Hi all!
This is referred to as Dye transfer
Here is some more info http://www.lttsolutions.net/dyetransfer.asp
Here is a post on Detailing world, which i did
http://www.detailingworld.co.uk/forum/show...ht=leather
Regards
Dave Naxton
Post #274587 Tue Aug 24 2010 9:53pm
I bought some leather wipes from Halfords in a resealable pack
They do the job nicely RRS gone
Post #284698 Tue Jan 04 2011 2:15pm
