Home > Maintenance & Modifications > DOOR PANEL SUPERCHARGED DECALS- How do I fit them? |
flight Member Since: 24 Jan 2008 Location: London Posts: 186 |
RANGE ROVER SPORT DOOR PANEL SUPERCHARGED DECALS
Thu Apr 16 2009 10:13am |
AndrewHG2 Member Since: 05 Sep 2008 Location: Harrogate Posts: 114 |
They pop out really easily, just lift from the right.
Thu Apr 16 2009 10:33am |
Another SW Member Since: 14 Mar 2009 Location: N Bucks Posts: 180 |
Don't they come ready fitted when you buy a Supercharged car? |
Thu Apr 16 2009 8:15pm |
L L
Fri Apr 17 2009 8:55am |
Fri Apr 17 2009 4:09pm |
Thankyou so much , ur amazing.
Fri Apr 17 2009 6:03pm |
Perhaps you`ve been sent the steering wheel badge ? Are they metal ? |
Fri Apr 17 2009 11:29pm |
Yes they are metal and I think you might be right...
Sat Apr 18 2009 12:06am |
mr boombastic Member Since: 08 Dec 2007 Location: NSW Posts: 40 |
I have also changed my badges to black and had the same problem. The badges are different depending on whether you have a supercharched sport or non supercharged sport. You have either been given supercharched door badges or maybe steering wheel badges. They do not fit in the holes of non supercharged models as they have metal backing. They are also slightly smaller.
Tue Apr 21 2009 12:49pm |
James W Member Since: 30 Mar 2009 Location: North Yorkshire Posts: 40 |
I've replaced all the green badges in and outside of my TDV8. The s/w and interior door trim badges are made of Tin (with a clearcoat/plastic laquered front).
Tue Apr 21 2009 12:54pm |
kedz Member Since: 10 Apr 2009 Location: manchester Posts: 151 |
do u think it would be a good idea to use a hair dryer on the steering wheel badge to make the glue soft so i can get it off?? |
Tue May 26 2009 9:50pm |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
Carefully drill small hole in centre. Put self tapping screw in and pull gently with pliers to release the metal prongs that hold the badge on.
Wed May 27 2009 10:54am |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 |
Agreed. There isn't any glue on the steering wheel badge, it's just held in with tin prongs (4 in total). Slowly and carefully prise it out. The new one will need to be stuck on (the prongs are cut off) with glue or 3m. Try and get a wafer thin tape otherwise it will look stuck on.
Wed May 27 2009 1:58pm |
thank's very much guy's |
Wed May 27 2009 3:01pm |
