Home > Technical > Sat Nav Not working
crose
United Kingdom 2005 Range Rover Sport TDV6 HSE Giverney Green
Sat Nav Not working
hi guys
The GPS icon in the top left hand corner has a red line through it and the pointer on the map screen is not showing the right position on the map.
Does anyone have any idea what might be wrong
Regards
Chris
Post #220104 Sat Mar 28 2009 5:26pm
It's normal - will self fix in a while. Often effected by weather conditions etc. 2005 Zambezi TDV6 - Gone but not forgotten
Post #220107 Sat Mar 28 2009 6:08pm
Another SW
Re: Sat Nav Not working
crose wrote:
hi guys
Regards
Chris
Are you in a garage? Or are you surrounded by tall buildings? Or in a deep valley?
GPS needs to be able to see at least 4 satellites in different directions (clear visual line of sight that is - with no solid objects in between) to be able to provide 3D navigation (and remove the red line from the GPS logo). But as VA says, it should sort itself out once you get out into the open.
Post #220108 Sat Mar 28 2009 7:34pm
PauloAmore
Scotland
I had that fault recently. I had a new GPS aerial fitted. 2022 P440e AB
Post #220114 Sat Mar 28 2009 9:57pm
crose
Thanks for all the replys.
Ive had this problem for about a week so suspect GPS aerial might be the problem.
Post #220136 Sun Mar 29 2009 10:17am
