![]() | Home > Technical > Sat Nav Not working |
It's normal - will self fix in a while. Often effected by weather conditions etc. 2005 Zambezi TDV6 - Gone but not forgotten
Another SW Member Since: 14 Mar 2009 Location: N Bucks Posts: 180 ![]() ![]() |
Are you in a garage? Or are you surrounded by tall buildings? Or in a deep valley? GPS needs to be able to see at least 4 satellites in different directions (clear visual line of sight that is - with no solid objects in between) to be able to provide 3D navigation (and remove the red line from the GPS logo). But as VA says, it should sort itself out once you get out into the open. |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
I had that fault recently. I had a new GPS aerial fitted. 2022 P440e AB |
crose Member Since: 28 Mar 2009 Location: United Kingdom Posts: 5 ![]() ![]() ![]() |
Thanks for all the replys.
