Home > General > washer fluid
bermyandy
2013 Range Rover Sport Supercharged Zermatt Silver
washer fluid
is there a warning if the washer fluid is low?
Nothing has been coming out the last few days, i get the odd bit out of the headlamp washers though
Im sure i can just pop the hood open but its mighty cold out!
Post #204791 Fri Jan 09 2009 10:57pm
dadanek
Czech Republic 2007 Range Rover Sport Supercharged Java Black
Yes, there is warning: "Low washer fluid" Cool RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT
Post #204796 Fri Jan 09 2009 11:09pm
jamiepyoung
It's the fuse.
Post #204889 Sat Jan 10 2009 2:37pm
MAW
It is - i had this - headlamps ok screen inop - good luck changing it Rolling Eyes you'll be better off buying a bag of spares from halfrauds IIRC rather than trying to get to the spares....
Fuseboard is behind the glovebox if you needed to know
Post #204893 Sat Jan 10 2009 3:09pm
PJPR01
United States 2006 Range Rover Sport 4.4 V8 HSE Cairns Blue
Easy enough to change the fuses...use a pair of long nosed needle pliers - GENTLY!
Makes changing the fuses a piece of cake... PJPR
Cairns Blue HSE
180k Miles of Adventure
Post #204906 Sat Jan 10 2009 4:11pm
MAW
I think the supplied fuse changer tool works well it just cannot get to the spare fuses IIRC
Post #204909 Sat Jan 10 2009 4:42pm
