![]() | Home > General > washer fluid |
dadanek Member Since: 30 Mar 2008 Location: Heart of Europe Posts: 450 ![]() ![]() ![]() |
Yes, there is warning: "Low washer fluid" |
jamiepyoung Member Since: 08 Dec 2007 Location: Finchampstead Posts: 31 ![]() ![]() ![]() |
It's the fuse. |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
It is - i had this - headlamps ok screen inop - good luck changing it |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 ![]() ![]() ![]() |
Easy enough to change the fuses...use a pair of long nosed needle pliers - GENTLY!
I think the supplied fuse changer tool works well it just cannot get to the spare fuses IIRC |
