Home > Maintenance & Modifications > Door handles removal
Page 4 of 4 <1234
V8 andy
England 2009 Range Rover Sport TDV8 HSE Arctic Frost
morning chaps,i'm just in the process of getting some chrome door handles or the covers i'm just wondering about these clips that break on removal & is it a ling job fitting them.
i'd prefer to put complete handles on instead of the stick on covers has anyone fitted the covers.? if so how secure are the..?
andy.
Post #233904 Wed Aug 19 2009 6:44am
dazsear
I dont think you can get chrome handles, only covers.
If you are changing the handles they dont worry about breaking the clips since the new ones simply clip in place. Be wary of the retaining springs on the front door handles since they are more of an issue if they fall into the door surround (like mine did).
As for the covers, I'm sure they work great if you use the correct glue.
Daz 2017 4.4 Autobiography FFRR - love this car
Gone - VW T5 Transporter
Long gone - 2009 Disco
Long gone but never out of my thoughts - 2008 TDV8 HST
Post #233915 Wed Aug 19 2009 8:34am
V8 andy
their on flee bay daz same price as complete handles but less hassle.
Post #233975 Wed Aug 19 2009 5:34pm
dazsear
Andy
Re-read my first line mate......I have seen the covers in all colours including carbon fibre.
I certainly think the covers are the way to go if you need a chrome finish.
I wanted black so decided to change the whole handles, much more hassle but a nicer end result!
Post #234079 Thu Aug 20 2009 7:49pm
V8 andy
how long to change daz..?
andy.
Post #234084 Thu Aug 20 2009 8:56pm
RobP
Don't know if I am mising something here but I just fitted a new set of handles
and although the clips on the old one did get a bit broken that was it, I didn't even see any springs??
These were the instructions the seller sent me, thought they might be of use
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #234085 Thu Aug 20 2009 8:57pm
dazsear
Looking at figure 3 they are simply covers that glue onto the handle body.
The springs are only an issue when you remove the handle body on the front doors.
Hope this helps
Post #234089 Thu Aug 20 2009 9:16pm
dazsear
Andy
I would say it can be done in less than an hour, once you resign yourself to the fact that you will damage the clips on the old bits you can simply adopt the bull in a china shop approach and just get on with it....lol!
Just remember that the torx screw on the lock mecinism (front passenger door) is only like a grub screw, turn it a few times a turn at a time and see if the lock will slide out before turning a further time and then you wont loose the screw, sounds complicated but obvious once you have done it. You access the head of the torx screw by removing a rubber gromet, visible when you open the door!!!
Hope this helps
Post #234090 Thu Aug 20 2009 9:21pm
RobP
Hope this helps
Daz
They don't glue on at all. They were original LR items that had been colour coded and clip into place the same way as the original ones. I dont see why it would be necessary to remove the whole handle mechanisim if you want colour coded ones. TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #234092 Thu Aug 20 2009 9:49pm
V8 andy
i take it you get new clips with the new handles then daz.
andy.
Post #234163 Fri Aug 21 2009 11:13am
dazsear
Yes mate the clips are part of the plastic piece (see figure 4) and they always break when you remove this piece, no big deal since you are replacing this bit of plastic anyway!
Post #234222 Fri Aug 21 2009 8:31pm
V8 andy
looks like i'll be ordering some then,many thanks for all the info guys.
andy.
Post #234247 Sat Aug 22 2009 9:41am
carlos50
Im going to do this as soon as the weather picks up, i wasnt aware that there are springs in the front doors?. I have complete 1 piece handles to replace and was advised of this procedure, is anything missing :-
Removal
1. Remove cap (not bothered if they break as have new ones)
2. Pull the handle outwards then slide it back towards the rear whilst held in the open position. The handle will disengage and can be removed along with the seals.
Fitting.
1. Push in the rear of the main handle
2. Angle the front of the handle towards the front of the car and slot in
3. Slide the handle forwards to lock in place
4. Fit the cap
The only deviation was the passenger side front door which needs the key to remove the cap.
Will using this procedure work fine or is a step / tip missing?
Thanks
Carl
Post #289662 Sat Feb 19 2011 6:32pm
Page 4 of 4 <1234
