Home > Technical > changing the plastic door card badges
the_atom
hi,
I bought a set of those door card badges from ebay, the coloured ones.
but how do i take the original black plastic ones out and put those new ones in.
Thanks,
Post #196940 Thu Nov 20 2008 8:54pm
I believe there are various screws concealed under the handles and behind the LR badge. The cards should also have simple poppers so a little tug Shocked should then get them off. I'm not 100% on this though. 2005 Zambezi TDV6 - Gone but not forgotten
Post #196942 Thu Nov 20 2008 9:03pm
the_atom
Do i need to take off the whole door card to change the little badge? maybe i need to reconsider installing them Smile
ANYBODY NEED SOME DOOR BADGES? hehe
I mean these:
http://cgi.ebay.co.uk/RANGE-ROVER-sport-DO...6003r20723
Post #196943 Thu Nov 20 2008 9:15pm
sorry misread you post, you should be able to pop these off and there is a single screw that keeps them in place I think. 2005 Zambezi TDV6 - Gone but not forgotten
Post #196945 Thu Nov 20 2008 9:17pm
rrsjo
There is an old post on how to do this which covers both the steering wheel and the door badges and has the bonus of photos. Try a search under 'badges' (From memory you the door badges are removed by flicking one side out and swinging the badge out on its hinge prior to removing a screw which holds the badge assembly in place - your replacement badge should enable you to see which side you have to flick out) Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #197033 Fri Nov 21 2008 5:26pm
the_atom
i just found out that they are too small. Sad Crying or Very sad
ive got a ffrr and the supercharged coloured badges are smaller.
Post #197040 Fri Nov 21 2008 8:55pm
