![]() | Home > Technical > changing the plastic door card badges |
I believe there are various screws concealed under the handles and behind the LR badge. The cards should also have simple poppers so a little tug |
the_atom Member Since: 29 Jul 2008 Location: the moon Posts: 15 ![]() |
Do i need to take off the whole door card to change the little badge? maybe i need to reconsider installing them |
sorry misread you post, you should be able to pop these off and there is a single screw that keeps them in place I think. 2005 Zambezi TDV6 - Gone but not forgotten
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 ![]() ![]() ![]() |
There is an old post on how to do this which covers both the steering wheel and the door badges and has the bonus of photos. Try a search under 'badges' (From memory you the door badges are removed by flicking one side out and swinging the badge out on its hinge prior to removing a screw which holds the badge assembly in place - your replacement badge should enable you to see which side you have to flick out) Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
i just found out that they are too small. |
