![]() | Home > Technical > Petrol Cap |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
Fault. Take it to a dealer unless any of the techies on here know the answer TDV6 - gone
Jonnylp Member Since: 18 Sep 2008 Location: Cheshire Posts: 78 ![]() ![]() ![]() |
Thanks Josh, will book it in and wait for any helpful suggestions as well. |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
mine locks up when the car is closed..... i would say: dealer...
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 ![]() ![]() ![]() |
The fuel flap on UK spec vehicles should lock with the central locking button. It sounds like you have a sticking actuator.
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Inside the boot there is a flap to manually release the cap - might it be worth 'exercising' this a couple of times to see if it 'resets' - agree dealer prob unless the trip is a pain - may be worth trying first anyhow...
Messing with the cable behind the RH rear quarter trim won't make any difference in this instance. If the actuator has jammed in the open position it will need to be replaced. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
No way it would unjam?
The problem is that the plastic tip at the end of the actuator cable gets chewed up a bit because it has not been aligned with the fuel flap locking clip properly.
Apart from it locking when it wasn't |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 ![]() ![]() ![]() |
I have to wonder then why the US models don't get this same feature...as it exists on practically every other European car here as well. PJPR Cairns Blue HSE 180k Miles of Adventure |
That's cuz it only costs about about 6 shillings to fill a tank over there. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
Valid point there TB...we are relishing $1.95 / US gallon gas again for 87 and 2.20 for 93...have to enjoy it while we can as the rest of the economy goes down the drain for a while. PJPR
$1.95 a gallon !!!
Now down to 1.78 for 87 Unleaded and 1.98 for 93 Unleaded! |
