Home > Technical > Petrol Cap
Jonnylp
Petrol Cap
Aplogies if this has been addressed before however couldn't find any other threads.
It seems that the flap covering the petrol cap doesn't actually lock when the car is locked up and anyone could come along and access the tank.
Is this a fult on my RRS ? (Its an '06 2.7TDV6), or is this how it is meant to be ?
Seems a little unsecure Sad
Post #196159 Fri Nov 14 2008 1:06pm
Josh
Fault. Take it to a dealer unless any of the techies on here know the answer TDV6 - gone
TDV8 - gone
Post #196162 Fri Nov 14 2008 1:17pm
Jonnylp
Thanks Josh, will book it in and wait for any helpful suggestions as well.
Post #196173 Fri Nov 14 2008 2:15pm
mine locks up when the car is closed..... i would say: dealer...
Post #196177 Fri Nov 14 2008 2:20pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
The fuel flap on UK spec vehicles should lock with the central locking button. It sounds like you have a sticking actuator.
It's a trip to the stealers I'm afraid. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #196183 Fri Nov 14 2008 2:24pm
MAW
Inside the boot there is a flap to manually release the cap - might it be worth 'exercising' this a couple of times to see if it 'resets' - agree dealer prob unless the trip is a pain - may be worth trying first anyhow...
Rolling Eyes
Post #196212 Fri Nov 14 2008 3:17pm
TB
Messing with the cable behind the RH rear quarter trim won't make any difference in this instance. If the actuator has jammed in the open position it will need to be replaced. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Post #196224 Fri Nov 14 2008 3:38pm
MAW
No way it would unjam?
At least it is stuck open and not closed Confused
Post #196252 Fri Nov 14 2008 5:02pm
TB
The problem is that the plastic tip at the end of the actuator cable gets chewed up a bit because it has not been aligned with the fuel flap locking clip properly.
If the fuel flap sticks in the locked position, you can sometimes realign the clip by wiggling the cable. You know when you have realigned the cable because the fuel flap springs open. In this instance you have no way of knowing if everything has been re aligned or not. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Post #196254 Fri Nov 14 2008 5:09pm
MAW
Apart from it locking when it wasn't Wink
Laughing
Either way Johhny let us know the fallout...
Post #196265 Fri Nov 14 2008 6:10pm
PJPR01
United States 2006 Range Rover Sport 4.4 V8 HSE Cairns Blue
I have to wonder then why the US models don't get this same feature...as it exists on practically every other European car here as well. PJPR
Cairns Blue HSE
180k Miles of Adventure
Post #196302 Fri Nov 14 2008 9:26pm
TB
That's cuz it only costs about about 6 shillings to fill a tank over there. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Post #196303 Fri Nov 14 2008 9:30pm
PJPR01
Valid point there TB...we are relishing $1.95 / US gallon gas again for 87 and 2.20 for 93...have to enjoy it while we can as the rest of the economy goes down the drain for a while. PJPR
Cairns Blue HSE
Post #196312 Fri Nov 14 2008 11:56pm
TB
$1.95 a gallon !!!
Two or three months ago we were paying more than that per litre. Shocked Shocked
Good old Blighty. Thud Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Post #196354 Sat Nov 15 2008 4:21pm
PJPR01
Now down to 1.78 for 87 Unleaded and 1.98 for 93 Unleaded! Very Happy PJPR
Cairns Blue HSE
Post #196467 Sun Nov 16 2008 8:11pm
