![]() | Home > General > Snow Chains !? |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 ![]() ![]() ![]() |
Are they not?
Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187 ![]() ![]() ![]() |
Killerbob you should check out this it goes on 20" wheels. They should cost around EUR 120
Killerbob Member Since: 27 Sep 2008 Location: St. Gallen Posts: 145 ![]() ![]() ![]() |
hmmmmm
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Yes, that's the same reason why is better to go with winter tires around here, even if the RRS could handle snow on summer tires(even if the crash is not your fault you'll get at least part of the blame.) I went for the 19", yes they are expensive here, but I like to have that bit of shoulder more for winter, still looking for chains, even if I'll probably never use them. '08 RRS TDV8 I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
Steve in germany Member Since: 15 Nov 2007 Location: Bad Lippspringe Germany Posts: 980 ![]() ![]() |
Not in the snow.... wider the better Speed Limits! not where I live! Back in a D3 Did have: RRS TDV8 2008.5MY Did have: Q7 3.0TDi S-Line/Tech/Comms pack Did Have: Disco3 HSE |
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 ![]() ![]() ![]() |
In my experience a narrow tyre works better in most snow conditions as it allows the tyre to cut down through the snow and get some grip inside or underneath the snow. It also creates a "tram line" effect that allows the vehicle to keep its line. A wider tyre can mean the car almost "floats" on top of the snow and doesn't get any traction or directional stability. I guess in really deep snow - wider tyres may mean the vehicle wouldn't "belly out" on the snow. The guys from countries that get lots more snow than we have in the UK will have better wisedom on this. RRS TDv8 HSE Rimini Disco 4 TDv6 HSE Ipanema Defender 90, 200tdi CSW |
A couple of inches fine, that allows you with the weight of the vehicle to get down to the roadsurface, whether that be tarmac or gravel etc and keep traction. However, if your talking proper snow, wide tyres with low pressures are a must. Just look at the guys in places like Canada, Iceland, Norway etc, they run on a min of 38" upto 44" Speed Limits! not where I live!
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 ![]() ![]() ![]() |
How far north are you thinking of going Josh. ![]() ![]() ![]() __________________ Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!! |
TheLynxEffect Member Since: 07 Nov 2007 Location: Midlands Posts: 38 ![]() ![]() ![]() |
I took my RRS to Val D'Isere last year and off to Switzerland this year and never had a reason to use Snow chains. Even before the roads had been cleared, the Pirellis did the job adequately as long as you drive sensibly and use the Snow Traction setting.
What about that www.easy-winter.com for EUR 56 ![]() |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
One of the greatest programmes ever made ![]() ![]() Joint runner up - 2009 Outstanding Contribution Award ![]() WINNER - 2008 ‘Best Thread’ Award – Beautiful Women Of The World ![]() Runner Up - 2008 Comedian Of The Year Award ![]() Runner Up - 2008’s Funniest Incident ![]() 06 RRS TDV6 HSE, Java/Ebony, PTI, Running Boards, Privacy, S/C Grille/Vents, Stormers, Tasmods - GONE - ![]() |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
Oh somewhere around northern edge of Yorkshire Dales depending on what's available in 2 years time ![]() TDV8 - gone Audi Q5 3.0 Tdi Sline wef 6/11/10 |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
it will start snowing here today |
