Home > Technical > Cannot get in to trip computer |
gazza500 Member Since: 01 Aug 2007 Location: Channel islands Posts: 176 |
No matter how I try I cannot get in to the on screen trip computer using the left hand stalk. Is this a known issue? How did you get around it?
Mon Nov 03 2008 8:53am |
Does the "i" button not work at all?
Mon Nov 03 2008 8:58am |
Hi Shmoogle,
Mon Nov 03 2008 9:01am |
Hmm... well, clearly that's not right. Has it ever worked? If it has and now it doesn't... then I guess there's an electrical contact issue. Time to drop by the dealer I suppose
Mon Nov 03 2008 9:03am |
Thanks mate Chawton White TDV6 HSE with Alpaca and Rodium, Automatic Climate Control,
Mon Nov 03 2008 9:15am |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 |
I think you can only access the changeable functions whilst stationary.
Mon Nov 03 2008 10:48am |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Correct - settings access only whilst static - MPG, range etc at all times
Mon Nov 03 2008 11:28am |
Korenai Member Since: 05 Oct 2008 Location: Lugano Posts: 244 |
If it still not working, go for a soft reset. |
Mon Nov 03 2008 1:38pm |
It sudddenly came back again, no rhyme no reason Chawton White TDV6 HSE with Alpaca and Rodium, Automatic Climate Control,
Tue Nov 04 2008 6:39pm |
At some point, my trip was stuck in settings... Couldn't go back or change anything. Turn it off, waited a couple minutes, everything was fine. No need to worry I guess. |
Wed Nov 05 2008 9:51am |
