![]() | Home > Technical > Cannot get in to trip computer |
gazza500 Member Since: 01 Aug 2007 Location: Channel islands Posts: 176 ![]() ![]() ![]() |
No matter how I try I cannot get in to the on screen trip computer using the left hand stalk. Is this a known issue? How did you get around it?
Does the "i" button not work at all? |
Hi Shmoogle,
Hmm... well, clearly that's not right. Has it ever worked? If it has and now it doesn't... then I guess there's an electrical contact issue. Time to drop by the dealer I suppose |
Thanks mate |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
I think you can only access the changeable functions whilst stationary.
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Correct - settings access only whilst static - MPG, range etc at all times
Korenai Member Since: 05 Oct 2008 Location: Lugano Posts: 244 ![]() ![]() ![]() |
If it still not working, go for a soft reset. |
It sudddenly came back again, no rhyme no reason |
At some point, my trip was stuck in settings... Couldn't go back or change anything. Turn it off, waited a couple minutes, everything was fine. No need to worry I guess. |
