Home > Maintenance & Modifications > better response and no smoke.....it is possible....read on
gazza500
Jersey 2008 Range Rover Sport TDV6 HSE Chawton White
I can confirm that putting some T2 in the fuel does have some amazing effects on the general performance of the engine.
Thanks to RRSport my RRS is even nicer to drive Bow down Chawton White TDV6 HSE with Alpaca and Rodium, Automatic Climate Control,
Privacy Glass, 22 inch, Hawke Alloy Wheels, Brembo Front Brakes, Premium ICE Pack, Clear repeaters, Chrome Driving Light Surrounds, Tasmods, Chrome handles, HST Grille, Chrome Side Vents, JE ECU Upgrade
Post #193207 Mon Oct 27 2008 11:07am
Korenai
Switzerland 2007 Range Rover Sport TDV6 HSE Java Black
Ok, I'll go for it as well... I found some semi-synthetic JASO FC 2-stroke oil at 4.4 £/L.
Post #193209 Mon Oct 27 2008 11:11am
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
I'm trying it in my old wheezy TD6 FFRR.
I guess you don't see instant results so I shall wait till I have done 3 tanks of fuel before I report back
Anyone else trying it? L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #193289 Mon Oct 27 2008 10:04pm
BigMart
You will see instant results , the next time you do a cold start , Thumbs Up
it gets better over the first three and then you'll wonder why more people dont do it.
Mart Jaguar XF 3.0D Portfolio
RRS TDV6 HSE 2006 , Zermatt , Gone
Post #193319 Tue Oct 28 2008 7:11am
Korenai
Full tank of Shell V-Power diesel, 400 ml of oil and 350 kms later... A little bit quiter (maybe) and less smoke... For now, it is all. Thumbs Up
Post #193771 Thu Oct 30 2008 1:27pm
jjb218
2006 Range Rover Sport Supercharged Zermatt Silver
What kind of oil 2t? Synthetic, mineral, sythetic mix??
Hello, I read the post and I was on my way to the Marina and discovered that the only 2 stroke oil was for marine outboard engines, one was mineral (didnt say anythign about synthetic) and the other one said " synthetic mix(es).
I live in a country where diesel quality completely sucks, and I mean bigtime! What can we do on this?
Thank you!
JJB
Post #195075 Thu Nov 06 2008 8:17pm
BigMart
Hi JJB,
mineral 2 stroke is ok , semi synthetic is fine but DO NOT use fully synthetic , it leaves a residue that mineral does not.
Jaso FB, FC or FD (the best)
This equates to ISO EGB , EGC or EGD
If you are using marine stuff the USA boys use TCW3 'cos the marine stuff is more readily available in some states.
Make sure it says mineral or semi synth and low ash .
Hope this helps
Post #195077 Thu Nov 06 2008 8:33pm
RRUK
An update:
I've been adding 2 stroke oil as per the thread above and my conclusion is pretty inconclusive!
I did not notice the car being quieter on cold start
I did not notice there was less smoke under throttle
I did not gain any fuel economy, if anything, it dropped slightly by about 1mpg on average over the 4 tanks of fuel I tried it with.
Other people apparently have seen good results. Nothing bad came of it but I think I'll not bother. Worth a try. L319 D4 HSE
1982 Series 3 SWB
Post #195861 Wed Nov 12 2008 7:10pm
BigMart
My update,
on the regular run to my office , West midlands to St Neots , Cambs..96 miles, I usually see 31.6-31.9 on a regular basis.
Since using a drop of 2 stroke it's up to 34.8 as from today. Shocked
Just about a 10% improvement.
I'm curious to see if the good times continue.
Flippin eck she's frugal.
Post #196304 Fri Nov 14 2008 10:30pm
Killerbob
Switzerland 2009 Range Rover Sport TDV8 HSE Java Black
It's funny to see how we keep re-inventing things:
I was using 2-stroke oil in my Volvo Penta 8 cyl. Dielsel boat engine for years. We had a much high mix ratio, but it was like night and day compared to when just using straight diesel.
Also when I lived in Scandinavia, driving a Mitsu Diesel I was adding 2-stroke, and never thought anything of it. Of course when I get my new TDV8 I'll put in 2-stroke, just looking for the right brand to use, which I can get here in CH.
KB RRS TDV8, black with ivory.
Post #196394 Sun Nov 16 2008 7:29am
Korenai
I'm in Switzerland as well, I'm using the FC semi-synth 2-stroke oil from Coop, found in the do-it section, 7.90 CHF/L, it does the job well! Thumbs Up
As long it's semi-synth and AT LEAST FB, it's ok, no need to worry about the brand.
Post #196429 Sun Nov 16 2008 1:09pm
