![]() | Home > Maintenance & Modifications > Is this Remapping mallarky really worth it? |
ademergen Member Since: 20 Jul 2008 Location: Portsmouth Posts: 41 ![]() ![]() ![]() |
Hey guys, as u can imagine my Tdv6 is beginning to feel slightly sluggish... just wondering if anyone has any experience of chip tuning on a tdv6? does it actually increase mpg? What really p |
Jonathan Member Since: 11 Jan 2008 Location: York Posts: 434 ![]() ![]() ![]() |
Hi
Rupert Member Since: 13 Mar 2006 Location: Here !!! Posts: 1194 ![]() ![]() |
I don’t think the service guys will know it’s re-mapped. But I recall reading that as soon as the garage hook up their diagnostic machine to the RRS & upload any updates, or do any tweaks it over writes the re-map returning the ECU to the default LR settings. Which will then require you to have the re-map done over again, after each service. Now I could be raving here & I’m sure someone better in the know than I, will come along, with a more definitive answer on this. But in the meantime it would be something to do some research on. As it would be a right pain to have the re-map done over & over again !! |
bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496 ![]() ![]() ![]() |
Hi
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Why is a separate module necessary?
There is quite a lot if difference between a bike ecu and a fully CAN controled ecu that is on the TDV6 Lion engine.
evolve Member Since: 30 Jun 2008 Location: Bedfordshire Posts: 25 ![]() |
The main reason is to eliminate the use of Windows on the PC which is not the most stable operating system. |
bex Member Since: 24 Mar 2008 Location: Abingdon Posts: 179 ![]() |
I understood it was so that the tuning software couldnt be cloned off the laptop as it is very easy to copy windows based programs? |
Our sub dealers use Windows based software and the tuning software/files are encrypted so they can not be easily copied. Of course nothing is impossible... |
