![]() | Home > Australia & New Zealand > Diesel Additive - Engine Cleaner |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
Any one use anything to give the internals a good clean out. I believe the diesel down here is not to EN standards so subject to varying particle levels. Mate noticed when i was driving it on the freeway last week, it was easy to see when i accelerated or the vehicle changed up due to the "toxic tractor" plume that emitted from the exhaust..
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 ![]() ![]() |
This is good for tractor juice drinkers......worked a treat in my Disco 3 |
thanks for that, do you use it on every fill up or just once every x n fill ups
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
What about the 2 Stroke oil theory? Apparently a 2 Stroke mix at 1:200 gives less emissions and better economy. Anyone been adding it each fill? There was a thread about it sometime ago. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
